Project ugly duckling
Re: Project ugly duckling
Postby dazedandconfused » Sun Jul 13, 2014 5:55 pm
Well thanks to Chris I got a condenser today. Pulled vacuum for an hour at 30. Left it sit for 20 minutes it dropped to 25 and stayed there for an hour and a half. Filled the system with 6 ounces of pag 100 oil with dye then 2 pounds of R134A. Its not working as it should and I can't figure it out.
This is the chart I was going by. Its 80 outside when I charged it. This was after I had to hotwire the compressor to make it work. New expansion valve, sensor in valve, drier and flushed entire system. Any ideas?
Postby dazedandconfused » Sun Jul 13, 2014 6:07 pm
Just got home and checked it again. Its 75 outside and the truck was cooling down to 59. Here is the pressure.
Postby oldestof11 » Sun Jul 13, 2014 7:15 pm
Im assuming on MAX AC and fan on HI right?
Is the compressor kicking on and off or just staying on?
Postby ellis93 » Sun Jul 13, 2014 7:42 pm
My money is on a pos exp valve, aftermarket are horrible.
Have you drivin it running the system yet?
Wet the condenser when idling and see if the air gets colder, and watch the pressures.
Postby dazedandconfused » Mon Jul 14, 2014 2:50 am
Max ac with the fan on high. The compressor won't come on unless I hot wire it. I drove it home and that last picture was of the pressures after getting home. What controls power through the ac system?
Postby dazedandconfused » Mon Jul 14, 2014 12:17 pm
Ran it all the way home but wouldn't cool below 70. Pulled in drive and checked pressures again. Low side was 32 and high side was 235. So is there anything you can do to the expansion valve to try and help pressures? Any other vehicle that shares the same expansion valve I could find in the junkyard?
Postby ellis93 » Mon Jul 14, 2014 1:28 pm
Don't know Andy.
Was that valve a Murry brand? If it was try another. Or another brand.....maybe AZ
Postby ellis93 » Mon Jul 14, 2014 1:30 pm
It took 3 Murry exp valves before I got a good one....FWIW.
Postby dazedandconfused » Mon Jul 14, 2014 1:41 pm
Compressor works was the brand I believe. I was wondering if maybe I didn't pull vacuum enough before charging? I pulled for 20 minutes and let it sit for 10 minutes. Then I pulled it for an hour. The box is cold to the touch and the expansion valve is cold. Did you have to replace the drier every time too?
Postby cmann250 » Mon Jul 14, 2014 2:53 pm
Andy, I think I have one or two expansion valves that are older ones. I have no idea if they work, but they aren't the new ones that seem to never work. Let me know if you are interested.
Postby dazedandconfused » Mon Jul 14, 2014 3:07 pm
I'm more then intrrested Caleb. Shoot me a text and let me know what you want for them.
Postby ellis93 » Mon Jul 14, 2014 3:20 pm
dazedandconfused wrote:Compressor works was the brand I believe. I was wondering if maybe I didn't pull vacuum enough before charging? I pulled for 20 minutes and let it sit for 10 minutes. Then I pulled it for an hour. The box is cold to the touch and the expansion valve is cold. Did you have to replace the drier every time too?
Just once,as long as you don't have it open to outside air for more than a few days it will be fine.
Vacuuming the system is just to remove the air and moisture from it. If your fooling with an old system then you'd do it a long time(especially if you've had it open to atmosphere for a while) to dry out the system and the desiccant bag in the dryer/accumulator.
If I install a new dryer with the rest of the system I generally don't pull a vacuum for so long. Really I let it drag down to 28 or30 and stop,letting it sit to check for leaks for a few min,then charge the system. All that sitting and waiting stuff cost me money so I tend to just get it done ASAP.
Postby dazedandconfused » Mon Jul 14, 2014 3:22 pm
Okay I just didn't want to have to keep buying driers since they have to be ordered.
Postby RumbleFish » Mon Jul 14, 2014 6:50 pm
I wish i could replace my murray expansion valve but dont want to lose my precious r12. I need a recovery machine lol
Postby dazedandconfused » Sat Jul 19, 2014 6:15 am
Well still fighting the ac issues but its half ass working. My brother and myself went to Louisville yesterday and picked up another bed I found for $150. Was suppose to go get one in TN for $400 but found this one instead.
