This is the chart I was going by. Its 80 outside when I charged it. This was after I had to hotwire the compressor to make it work. New expansion valve, sensor in valve, drier and flushed entire system. Any ideas?
dazedandconfused wrote:Compressor works was the brand I believe. I was wondering if maybe I didn't pull vacuum enough before charging? I pulled for 20 minutes and let it sit for 10 minutes. Then I pulled it for an hour. The box is cold to the touch and the expansion valve is cold. Did you have to replace the drier every time too?
Users browsing this forum: No registered users and 79 guests
