So while I'm driving it will bounce up to 50 then back down. What I have noticed if as I hit the throttle it will bounce up but when I let off it sits as 0.
Any advice would be appreciated guys
CumminsPower59 wrote:Check the drive that the VSS goes into. Make sure stuff isn't all worn out, causing the drive for the VSS to slip and catch.
