Electrical Theory question
Postby cmann250 » Wed Sep 24, 2014 4:41 pm
I didn't want to muck up the BS thread :lol:
I did an engine swap on a lawn mower not long ago. Now I'm trying to figure out the ignition. The original engine had a "regulator" in the ignition circuit. I have the regulator in front of me. It has 3 wires coming out of it that I'm calling "left", "hot", and "right". See picture.
When I connect my ground probe to the "hot" wire and the hot probe to the left wire and I get 56x ohms of resistance. I do the same to the right wire and I get 54x ohms. No other two wires show resistance so I believe that there are no other ways to make a circuit.
What do these wires do? How do I tell which is power and ground? Of course I could have kept the original engine to find what they do, but its gone. I recall that my tractor has a regulator in the ignition circuit because back in the day coils weren't as good as they are today.
Why don't they teach this chit in schools?
Re: Electrical Theory question
Postby PToombs » Wed Sep 24, 2014 4:59 pm
Is that the one that goes to the current engine or the previous one?
Are there 2 wires coming out of the shroud? I think that's a rectifier, AC from the stator comes out to the yellow wires, and the rectifier converts it to DC on the red wire which goes to the battery, lights, electric clutch or whatever. Pics of the wires on the engine may help.
Postby cmann250 » Wed Sep 24, 2014 5:11 pm
This is from the original engine. There are 2 wires coming from the new engine. One is a ground and the other I assume is to the coils. Another wire comes from the engine and feeds 12 v to the red wire.
I assume if I feed the coils 12 v directly, it'll smoke them.
Postby BILTIT » Wed Sep 24, 2014 6:48 pm
It is a regulator/rectifier in one package.
Derek B.
BILTIT
Postby cmann250 » Thu Sep 25, 2014 3:01 am
So it's impossible to hook it up backwards?
Postby BILTIT » Thu Sep 25, 2014 7:34 am
Not impossible, just be sure to hook the wires up as shown in the picture.
Derek B.
BILTIT
Postby cmann250 » Thu Sep 25, 2014 9:14 am
I know the red wire needs 12 v to it. On the new engine, one wire is grounded and one isn't.
How do I tell which wire on the engine goes to which yellow wire on the regulator?
Postby BILTIT » Thu Sep 25, 2014 10:34 am
Nope the red wire has 12v coming out of it, the input is the two yellow wires from the stator.
Sounds like you already have a rectifier on the new engine as it only has two wires, Its a different setup.
Derek B.
BILTIT
Postby PToombs » Thu Sep 25, 2014 3:30 pm
Biltit showed what I was talking about. Maybe you should pull the shroud and make sure where the wires go. One may go to the coil to for a ground to shut it off.
Postby cmann250 » Thu Sep 25, 2014 5:02 pm
I'll have to dig into it. Owning a 12 v has not helped sharpen my electrical skills.
Thanks to both of you.
Postby PToombs » Fri Sep 26, 2014 5:48 pm
cmann250 wrote:I'll have to dig into it. Owning a 12 v has not helped sharpen my electrical skills.
Wow, that's sad! It should have helped immensely! :lol:
Users browsing this forum: No registered users and 76 guests
