Fuel pump
Fuel pump
Postby Promod631 » Mon Oct 06, 2014 8:07 pm
I put in a h&s fuel pin in my truck and wondering if I should turn the fuel up on the ve pump? What gains will I get and what losses?
Promod631
Re: Fuel pump
Postby jay » Wed Oct 08, 2014 10:01 pm
Have you touch the power screw yet?? If not I would and also bump your timing.
92 D350 CC bd diesel fuel pin and governor spring timing advanced 6 degrees power screw turned.Had a 93 D250 CC denny t fuel pin 3200 governor spring timing advanced 6 degrees power screw done 100 hp DSS injectors he 351 turbo dual disc clutch
jay
Re: Fuel pump
Postby jay » Wed Oct 08, 2014 10:04 pm
As for gains my 93 with no pin or timing and a 5spd truck I went from bone stock 160hp to 194 at the wheels and for loss I gain in mpg.
jay
Re: Fuel pump
Postby Promod631 » Sun Oct 12, 2014 5:22 pm
I bumped up the timing and just found out about the power screw
Promod631
Re: Fuel pump
Postby oldestof11 » Sun Oct 12, 2014 6:32 pm
Is an auto or manual?
Re: Fuel pump
Postby Promod631 » Sun Oct 12, 2014 7:49 pm
manual or as my son calls it the man trans
Promod631
Re: Fuel pump
Postby oldestof11 » Mon Oct 13, 2014 3:07 pm
Fuel pin, power screw to the collar will definitely be felt.
I had a Denny T stage 1, rebuilt stock injectors, K$N air filter, 4" exhaust, 4k gov spring, 60 lbs valve springs, and banjo bolts drilled. All in all, I ran a best of 15.54 and backed it up with runs in the 15.5-15.6 range, all at 84mph. 6200lbs. So 270-290 flywheel hp. It scooted for its size.
Re: Fuel pump
Postby Promod631 » Mon Oct 13, 2014 7:37 pm
On mine its got h&h fuel pin, stock injectors, 4 inch exhaust, and k&n filter. The way I built it is the old cab was rotted out so I redid the whole truck. There are at least parts from 4 different trucks. I estimate it around 4000 pounds and the way it is and it hauls the mail!
Promod631
Re: Fuel pump
Postby oldestof11 » Mon Oct 13, 2014 8:09 pm
4000lbs? That sounds light.
Re: Fuel pump
Postby Promod631 » Tue Oct 14, 2014 4:25 pm
yep. its all gas truck frame body everything except the motor. But I should get it on the scale soon enough.
Promod631
Re: Fuel pump
Postby cmann250 » Tue Oct 14, 2014 4:44 pm
My '89 regular cab D250 weighed 5300 with me (150) and a tool box (200) in it. It had the short frame.
Re: Fuel pump
Postby jethro » Tue Oct 21, 2014 8:24 pm
Jay- did you say you went from 160 to 190 and GAINED MPG ????????
Is that correct ?
jethro
Re: Fuel pump
Postby Promod631 » Sat Nov 01, 2014 9:26 pm
I just turned the pump up at the start of the weekend and its a big improvement over before. It'll be my sons truck and it will be fast enough for him. :lol:
Promod631
