New here
Stop in and say hi
New here
Postby Samsonite » Sat Oct 18, 2014 2:06 pm
New to the forum. Had a few diesels and recently got a 93' W250. Getrag trans. Truck has had a lot of work done by prev owner, and myself. May have seen it on CL. Tossing around selling it but at the same time still improving it.
First thing i did when i bought the truck was pull the head, replace the headgasket and stick in some ARP studs. After that i found a low mile ATS Aurora 3000 for cheap. Turned full fuel in all the way, starwheel ~2 turns from bottom, smoke screw ~1.5 turns down, ground the fuel pin etc...
Runs very strong. but of course i am wanting more and more. Had an 04 common rail with just stacked tuners, trying to get it comparable.
Bought a 2000 24V intercooler, and just ordered some 3" piping for it, so that is next. Looking for a good clean streetable injector also.
My main complaint is power off the line and between shifts. I typically start in 2nd gear (1st too low) and the truck tends to bog a bit before taking off. The 3000 lights better than the H1C but still too slow. Makes about 35 PSI and 1250 EGT max. Between shifts it doesn't pull as hard as my old 04 unless you really ring it out. Im sure it would feel a lot better at sea level but here in Denver it leaves me wanting more...... Is it possible??
Here are some PICS!
Samsonite
smoke screw?
Re: New here
Postby ellis93 » Sat Oct 18, 2014 4:42 pm
Welcome! Nice truck :)
Re: New here
Postby DMan1198 » Sun Oct 19, 2014 6:07 am
Welcome. If you're looking for a good injector for your truck I'd contact rccummins89 on here. He'll be able to help you get the right set of sticks for your setup
Re: New here
Postby oldestof11 » Sun Oct 19, 2014 7:54 am
Welcome!
Turn that smoke screw up and tighten the starwheel. Trust me on this. Responsiveness goes up.
Re: New here
Postby dazedandconfused » Sun Oct 19, 2014 8:10 am
Welcome.
Re: New here
Postby Samsonite » Sun Oct 19, 2014 8:23 am
oldestof11 wrote:Welcome!
I tried the starwheel tight and all i got was a worse bog and more smoke...I've heard mixed things on this. Some say that too much down low "puts out the fire". Kind of wondering if the factory intercooler is leaking. I just changed two boots out that were questionable and i could swear its spooling quicker now.
Thanks guys
Sam
Samsonite
smoke screw?
Re: New here
Postby DMan1198 » Sun Oct 19, 2014 11:36 am
Back the smoke screw all the way out at least
Re: New here
Postby RCCUMMINS89 » Sun Oct 19, 2014 2:47 pm
Good looking truck, and welcome to the forum.
Return to Welcome
