BC847 wrote:@ CumminsPower59: Great pics!
762frmafr wrote:For now it will be the stock turbo. But that was going to be my next question. Which turbo would be a good upgrade from stock. It will mainly be a daily driver with some towing. Hopefully more towing in the future. And if I upgraded the turbo would I have to do injectors at the same time?
RCCUMMINS89 wrote:Will an i/c grill fit a non i/c core support?
PToombs wrote:Nope! Piston lift pump needs a filter or screen before it or trash will scarf the piston and you will lose pressure. BTDT.
CumminsPower59 wrote:RCCUMMINS89 wrote:Will an i/c grill fit a non i/c core support?
Not sure, but my pile has the later grille and it wasn't intercooled....so I I'm not sure if the core support is a common NON-IC, or an oddity for just early 91's.PToombs wrote:Nope! Piston lift pump needs a filter or screen before it or trash will scarf the piston and you will lose pressure. BTDT.
^^^ This is good advice. I run a in line strainer by FleetGuard, FF5709. They are inexpensive and work well, catches all the larger chunks of garbage that's in the fuel
