Cummins/82 C10
Re: Cummins/82 C10
Postby ellis93 » Sun Nov 09, 2014 7:49 pm
Well....I don't want to run an electric pump alone and I don't need it kicking the bucket and causing the piston pump to starve for fuel. Dilemmas.... :scratch:
I'm gonna study on its some more...after the bypass reg is on and I actually find out what this piston pump will push.
Re: Cummins/82 C10
Postby ellis93 » Thu Nov 20, 2014 4:02 pm
Ok Ive just about decided that the high rpm rattle I'm hearing is the piston pump. It's like its floating on the lobe of the cam. Its a really loud slap, and only about 23 or 2400rpm.
It's coming off I guess and I'll be running the powerstroke pump I have for awhile,it really pains me to put it on the truck too :lol:
Re: Cummins/82 C10
Postby ellis93 » Thu Nov 20, 2014 5:37 pm
Looking on eBay I found this one
http://pages.ebay.com/link/?nav=item.vi ... 1492488385
Universal Walbro High Flow & Pressure External Inline 255LPH Fuel Pump GSL392
From what I've read looking from forum to forum,some are having good luck out of them. Have yall heard anything negative?
Re: Cummins/82 C10
Postby PToombs » Thu Nov 20, 2014 5:40 pm
Yeah, you said you were going to put that ford pump on. Not only is it negative, it's also depressing. :(
Re: Cummins/82 C10
Postby dazedandconfused » Thu Nov 20, 2014 5:41 pm
Doesn't BC run that or something similar?
Re: Cummins/82 C10
Postby ellis93 » Thu Nov 20, 2014 6:04 pm
PToombs wrote:Yeah, you said you were going to put that ford pump on. Not only is it negative, it's also depressing. :(
I know but it's what I have now. Since this one I found is similar in design,I can build the system like I want and after Christmas I can buy that fancy one.
Re: Cummins/82 C10
Postby ellis93 » Thu Nov 20, 2014 6:05 pm
dazedandconfused wrote:Doesn't BC run that or something similar?
I've no idea
Re: Cummins/82 C10
Postby ellis93 » Fri Nov 21, 2014 3:44 pm
Well the ps pump is on and the piston pump is gone....I ain't happy. It won't hold but 35psi when I'm in the throttle and it'll push 60 at idle. I'm gonna belly up to an airdog :?
Edit:
It actually acts a little better than the piston pump out on the road.....psi recovery is a lot faster. I just got to the house and put a hose pincher on the return line to the tank,just to see what more psi would do. I jacked it up to 70psi and only had it drop to around 55psi. I think my next item to play with is that overflow valve....I'm gonna delete it and run a boost sensing regulator I have on the dodge. Both times I've screwed with fuel supply,Ive ran into problems keeping it where it is at idle,when I really want it to increase with engine rpm.
Oh and my noise is still there,looks I'll be following Alice's rabbet down the hole :roll:
Re: Cummins/82 C10
Postby dazedandconfused » Fri Nov 21, 2014 7:02 pm
Before you jump on an air dog look at fuel lab.
http://fuelab.com/products/diesel/
Re: Cummins/82 C10
Postby ellis93 » Fri Nov 21, 2014 7:51 pm
Andy I'm going to fool around with that reg idea first then move on to another fuel supply. I like what I see there but I ain't crazy about the price at all. Schit is high
Re: Cummins/82 C10
Postby dazedandconfused » Fri Nov 21, 2014 8:04 pm
Yeah they are higher but I've yet to hear of a pump failure.
Re: Cummins/82 C10
Postby DMan1198 » Fri Nov 21, 2014 10:29 pm
That's what I want to go with when I do the lift pump on jaeger
Re: Cummins/82 C10
Postby ellis93 » Tue Nov 25, 2014 5:15 pm
Well I'm buying up new supply lines for the chevy and the dodge.
And an assortment of 1/2 compression fittings and the stainless air brake line inserts.
It's not the cheapest way to go for line but seeing the rubber line I have,connecting the metal lines,swell up I figure this won't be. :D
Re: Cummins/82 C10
Postby PToombs » Tue Nov 25, 2014 5:44 pm
1/2 inch tube is only 3/8 inside you know. I found that out when I did my truck. I went with 5/8, that's about 1/2 inch inside. Stuff works great though, I love it! 8)
Re: Cummins/82 C10
Postby ellis93 » Tue Nov 25, 2014 5:49 pm
I know,I don't figure on needing any bigger tho. I'll be running the largest electric pump I can find as a pusher and at crazy pressures. It should supply enough fuel to let the engine get enough fuel to twist the wimpy frame of the truck in half. Time will tell I guess :?
