Is this the right forum for dif questions? Reaend gear ID
Postby chevjerico » Fri Nov 21, 2014 9:25 am
Guys' how can I find out what gears my truck came with stock?
How much would it help my MPG going from 4.10 to 3.54? I don't even use 1st gear at all. Stock Getrag gear box.
chevjerico
Re: Is this the right forum for dif questions? Reaend gear ID
Postby BILTIT » Fri Nov 21, 2014 10:37 am
I dont use 1st gear with 3.54's and 33" tires either unless i am pulling fairly heavy.
What rpm at what speed with what size tires? We should be able to tell you just from that.
Derek B.
BILTIT
Postby chevjerico » Fri Nov 21, 2014 10:48 am
Thanks but it has 4.10 gears. Just wondered what it came with. I have the original window sticker, and I'm sure there is an axle code stamped on axle. Maybe other ways?
chevjerico
Postby BILTIT » Fri Nov 21, 2014 11:38 am
Take your VIN to the dealer, they can tell you what it had originally.
Why do you not think the 4.10's are original?
Derek B.
BILTIT
Postby chevjerico » Fri Nov 21, 2014 12:24 pm
The previous owner told me the gears had been replaced at some point when the truck was relatively new. Said he had to change out speedo gears to correct error.
How much MPG do you think I can get switching to 3.54 gears? I'm getting 17.8 MPG around town now, and actually I'm pretty happy with that. If I come across a good deal on a rearend or gear swap, I might give it a shot.
I can't imagine this truck needing any more then 3.54 to pull a load. Especially the loads I'd put on it. An open car hauler, and 4k lbs car. I guess around 6k lbs, or a small toy hauler probably of similar weight.
chevjerico
Postby chevjerico » Fri Nov 21, 2014 12:30 pm
BILTIT wrote:Take your VIN to the dealer, they can tell you what it had originally.
Oh hey Biltit, I love Venturas! I have a 70 Chevelle 4 speed, best ET is 11.85 on an econo built 400 with stock vortecs and different springs. I'm more a Buick, Olds, Pontiac guy, then Chevrolet.
chevjerico
Postby BILTIT » Fri Nov 21, 2014 1:15 pm
sweet, 11.85 is nice!
Rolled my first one.
Second one served me well for many years but is undergoing a minitub and diff narrow right now.
Derek B.
BILTIT
Postby chevjerico » Fri Nov 21, 2014 1:39 pm
Nice.....TA girdle and cheater slicks! Actually my best last time out was 11.97 @ 112 also!
chevjerico
Postby BILTIT » Fri Nov 21, 2014 2:12 pm
Haha thats funny.
Ya i needed the wide tires to hook on the street, we do alittle street racing around here :)
Derek B.
BILTIT
Postby PToombs » Fri Nov 21, 2014 6:45 pm
Love the rubber up on the quarters, that brings back some memories. :lol:
