RCCUMMINS89 wrote:I'd strongly advise against a denny pin. They are cut deeper than the pump can utilize and they eventually cause o ring leaks. Not on all trucks, but a high percentage of them.
762frmafr wrote:RCCUMMINS89 wrote:I'd strongly advise against a denny pin. They are cut deeper than the pump can utilize and they eventually cause o ring leaks. Not on all trucks, but a high percentage of them.
What would you recommend then? Not just in a fuel pin, but as far as turbo upgrades and fueling upgrades.
CumminsPower59 wrote:762frmafr wrote:RCCUMMINS89 wrote:I'd strongly advise against a denny pin. They are cut deeper than the pump can utilize and they eventually cause o ring leaks. Not on all trucks, but a high percentage of them.
Just my $0.02, but 370's perform great in a NON-IC engine
