Heater motor relay? No heater at all
Postby Firstgen11 » Thu Jan 22, 2015 9:53 pm
My heater just went out at once I put a switch on it no fix I put a power wire directly from the battery to the fan fan came on checked fuses all good checked fuse links all good I'm stumped anybidy have a resolution could it be the relay if so where is that sucker lol someone please help I need my heat
Firstgen11
Re: Heater motor relay? No heater at all
Postby Firstgen11 » Thu Jan 22, 2015 10:09 pm
Also is there a wire that sends power to the fan inside the piece you select where you want the heat to go like floor or defrost is there any power wires or anything in that thing that would keep it from turning on the fan also meant to say there is power on the wire coming from the fuse panel or wherever but it is also tapped into the washer fluid motor too so idk if it has power all the time or not but when the heater is on and I go test that wire it reads 9 something volts
Firstgen11
Postby Firstgen11 » Thu Jan 22, 2015 10:26 pm
Could it be the heater resistor thing?
Firstgen11
Postby CumminsPower59 » Fri Jan 23, 2015 11:20 am
Punctuation please ;)
The blend doors are vacuum controlled.
Double check the wiring, fuse and fusible links. Are you using a quality wiring schematic to trace the circuit? The blower motor resistor is on the firewall behind the glove box, open the glove box, flex the back panel to allow the assembly to pivot down more, and look up above the HVAC box. You'll see it.
Postby Firstgen11 » Sun Jan 25, 2015 8:04 am
Update I replaced the resistor the fan switch watched my doors move in and out I'm stummped right now not sure what is wrong it has to be wiring but idk where to start do I start at the fan switch or what
Firstgen11
Postby CumminsPower59 » Sun Jan 25, 2015 8:08 am
Look here.
viewtopic.php?f=30&t=11477
Trace out the circuit starting at the power source for the system.
Return to Electrical
