PToombs wrote:Shouldn't this thread be in the "Other POS" section instead of the lounge?
DMan1198 wrote:i see mention of a turbo swap. From what I can see Garrett has 3 versions of the gt38 (62, 64, and 67 all with a 74mm turbine wheel) the compressor maps don't show up, but if you're upgrading why not go to something like the gtx4088r? 65mm comp wheel , and 77mm turbine wheel. It's also a bb charger, so spoolup should actually improve over the gt38
DMan1198 wrote:Then that seems like a mistake to buy a v8
Remps wrote:What year of truck is it?
fatty wrote:What he said.
Cmann, sounds like you need to get back into a first gen. My buddy has a 01 7.3 that broke a PMR a few months ago. Sure would suck to have to replace an engine at only 300 HP because of crappy factory parts.
