Making a 518 lockup
Re: Making a 518 lockup
Postby txs » Mon Jan 05, 2015 7:43 am
Andy, the diesel trannies got the same shafts as the gassers, input, intermediate and output.
txs
Postby dazedandconfused » Mon Jan 05, 2015 7:45 am
I have a 47rh and two 518's. One is a 93 diesel and the other a 92 gas unit. Just figured I could make the 518 lockup since I have two trucks they need to be used in. I figure if the 518 has handled this beating for this long night as well freshen it and make it a lockup. So I should have all the pieces for the trans between the 2 I have?
Postby dazedandconfused » Tue Jan 06, 2015 11:16 am
So from my research I can use a 47rh with the 518 lockup input correct?
Postby txs » Wed Jan 07, 2015 8:41 am
Since I moved I can't find my engineering changes book, I would keep the input shaft and reaction shaft support together. Yes you can do that.
txs
Postby dazedandconfused » Sat Jan 31, 2015 1:24 pm
Postby Diesel » Sat Jan 31, 2015 2:58 pm
I'd like to get a used A518 and set it up with lockup to just swap in at once. Just trying to see if I understand correct...the VB must come from a 47RH as well as the torque convertor...but the rest of the parts can come from a 47re?
1991.5 D250 Intercooled A518
Diesel
Postby cmann250 » Sat Jan 31, 2015 3:44 pm
The valve body is the only 47RH specific part you'd need. The rest is just 47RH or RE lock-up stuff. Does not matter which.
Postby dazedandconfused » Sat Jan 31, 2015 3:45 pm
The 518 gas transmission parts will work as well.
Postby Diesel » Mon Feb 02, 2015 7:05 pm
dazedandconfused wrote:The 518 gas transmission parts will work as well.
Because 518 gas is lockup right? The torque converter is not 47rh specific also?
Diesel
Postby dazedandconfused » Tue Feb 03, 2015 3:59 am
Yes the 518 gas is lockup and run the 47rh convertor.
Postby Diesel » Thu Feb 05, 2015 7:25 am
I'm on it. Looking for a parts trans hopefully soon.
Diesel
Postby Diesel » Fri Feb 06, 2015 1:14 pm
Dumb question: is reaction shaft support the front pump on the transmission?
Diesel
Postby cmann250 » Fri Feb 06, 2015 2:49 pm
I replied to your PM, but here is a diagram
Postby Diesel » Thu Mar 12, 2015 10:00 am
So parts are being gathered!
Can anyone go into detail on how they made lockup automatic (instead of with a toggle)?
And can overdrive remain as it is not on my A518 via the TPS?
Diesel
Postby cmann250 » Thu Mar 12, 2015 11:57 am
Yes, your od can still function off the tps. You'll just need the 47rh plug. People have used governor pressure to lock the converter at a certain speed.
Return to Transmission
Users browsing this forum: No registered users and 93 guests
