VE no injection pressure...
Postby cummins12club » Sun Feb 01, 2015 12:34 pm
I worked on a friends 92 last weekend and had to pull the pump off because the O ring at the rotor head was leaking. The truck was running fine just leaking fuel badly. So we pulled the pump and pulled the rotor head, replaced the O ring and put everything back together making sure the two springs in the gov section sat in there pockets and the other two smaller springs stayd in there's. Put everything back together and the truck won't start. We cracked the lines and it's not shooting the fuel as it should. The fuel just dribbled out. I took the lines all the way off on the injector side and when you crank it the fuel just dribbles. It has good lift pump pressure, it's in time, rueled out the sthi off solenoid (took the plunger out) re indexed the gov spring. It has me stumped. I'm not familiar with the inner workings of the vane pump and rotor head. Are next step is to take the pump to an Injection shop and have them run it on there stand to find out what's wrong. Just figured I'd ask the VEinds here before going to that step
cummins12club
Re: VE no injection pressure...
Postby 1992gen1_fan » Sun Feb 01, 2015 2:20 pm
Is the full power screw in the same spot it was originally?
1992gen1_fan
Postby cummins12club » Sun Feb 01, 2015 4:23 pm
Yes
cummins12club
Postby jethro » Sun Feb 01, 2015 6:01 pm
maybe this is too obvious-- but check to see that the fuel shut-off lever on the side of the pump didn't get bumped
into the OFF position. I have never pushed mine- don't know if it is detented or spring loaded........
Just a thought.....
Tim
jethro
Postby RCCUMMINS89 » Mon Feb 02, 2015 3:24 pm
Make sure the little disc between the rotor shaft and the camplate went back into place?
Postby dpuckett » Thu Feb 05, 2015 11:40 pm
Is your rotor lined up with the tab on the cam plate, and lined up with the notch on the external shaft for the key? If that all is not lined up, it wont start, either.
