Cummins/82 C10
Re: Cummins/82 C10
Postby DMan1198 » Mon Feb 02, 2015 7:10 pm
Well chop chop, and takes pictures. As the banner that's available on some forums says (which I'm too lazy to look for). This thread is useless without pics
Re: Cummins/82 C10
Postby ellis93 » Mon Feb 02, 2015 7:22 pm
Tomorrow night.....I think :lol:
Re: Cummins/82 C10
Postby DMan1198 » Mon Feb 02, 2015 7:24 pm
I suppose that's fair
Re: Cummins/82 C10
Postby ellis93 » Tue Feb 03, 2015 11:23 am
Went ahead and did the deed this morning.
Dman here's your pic
I found a screw up I did.
Mashed the ground lug for the grid plate in between the air horn and grid body.
Doh!
Results of the injectors.....lots of power....too much for the converter.
Re: Cummins/82 C10
Postby dazedandconfused » Tue Feb 03, 2015 1:41 pm
Downhill spiral with power isn't it. Lol
Re: Cummins/82 C10
Postby ellis93 » Tue Feb 03, 2015 2:12 pm
It'll definitely have the convertor locked in second or third if I run it.
I didn't try it sitting still,I'm scared for the 10bolt,so I figured I'd mash on the go pedal rolling. It was all rpm rise and falling fuel psi with the converter unlocked. I tried it again locking it up in third and it did much better. The little 30psi vdo boost gauge was pegged out to.....I'd have to guess I'm around 35 or so lbs at wide open throttle.
Theres a way different feel to the truck.....almost little car like,nimble. I like :)
These injectors have found a permanent home 8)
Re: Cummins/82 C10
Postby dazedandconfused » Tue Feb 03, 2015 2:25 pm
That's just a cheap billet cover convetor isn't it?
Re: Cummins/82 C10
Postby ellis93 » Tue Feb 03, 2015 2:37 pm
Yep bottom of the barrel. Transtar rebuilt. It does have a bunch of miles on it tho,general truck use.
I need to find a one someone is getting rid of cheap. Cheapest thing I have found is around 800$
Re: Cummins/82 C10
Postby dazedandconfused » Tue Feb 03, 2015 2:53 pm
Have you checked with DPC? They do/did sell rebuilt convertors for decent money.
http://www.dieselperformanceconverters.com/page6.html
Re: Cummins/82 C10
Postby ellis93 » Tue Feb 03, 2015 4:02 pm
First I've heard of them Andy. I think I may call them up tho. I had thought about calling ptc and seeing if they'd rebuild this one since it already has the cover on it. Idk
Re: Cummins/82 C10
Postby cmann250 » Tue Feb 03, 2015 4:21 pm
LOL at the dwarf needing a milk crate to work on a 2wd :jumpsmile:
Re: Cummins/82 C10
Postby DMan1198 » Tue Feb 03, 2015 4:30 pm
Thanks Ellis.
Re: Cummins/82 C10
Postby ellis93 » Tue Feb 03, 2015 5:19 pm
cmann250 wrote:LOL at the dwarf needing a milk crate to work on a 2wd :jumpsmile:
I'd like to see you stand flat footed and reach to the back injector....loosen it while holding the lines off of it. I bet money you'd use a crate too :lol:
Yeah I'm short(5'9") what about it,that makes me closer to what counts.....on yo mama :lol:
Re: Cummins/82 C10
Postby ellis93 » Tue Feb 03, 2015 5:21 pm
DMan1198 wrote:Thanks Ellis.
Your welcome!
Re: Cummins/82 C10
Postby dazedandconfused » Tue Feb 03, 2015 5:23 pm
Ellis DPC is about the best converter builder around. His converters are running in the fastest and highest HP trucks around. I'll be buying one for one of these transmissions I have laying around.
