PToombs wrote:Don't look!
meby wrote:Can someone explain why the new 1500 trucks have better weight ratings than the old 2500 trucks? Am I missing something?
Remps wrote:Maybe pressurize the fuel tank to 10-20 psi and check for leaks, or put a check valve before the LP. On another note I bought myself a used ironman inversion table about a month ago for lower back issues. It does help some, usually only hang between 20 seconds to a little over a minute. The trick is to turn yourself upside down slowly to avoid a head rush. First time I did it I puked from doing it too quickly. I am glad I bought it, I use it almost every day.
