by ESC93W350 » Thu Mar 12, 2015 10:46 am
I Have adjusted the tv cable/linkage, checked the tps and don't get any voltage change when moving the throttle. I'll try the re-indexing the tps, but think it may be no good.
Everything was working perfectly until I had to replace the injection pump, but I know when electrical stuff goes, it just goes. Could the line pressure sensor on the cooler line cause this. It shifts fine through the othe gears, just won't engage o.d. at all. So I'm stuck back roading, since 55mph spins me at 2300rpm.
1993 W350LE 4x4 automatic clubcab dually. Banks Power Pack w/wastegated turbo. Starwheel,smoke screw, and fuel pin tweeks. Banks pyro and tach, Isspro boost gauge. GearVendors o/d, BD exhaust brake, Kelderman compuride rear bags, front bags.
