Cummins Excursion
Re: Ford project
Postby dazedandconfused » Sun Mar 01, 2015 9:48 am
Well I pulled the rest of the trans apart this morning. I fought 5th gear for over and your to get that dang thing off. Everything else looked great inside the transmission though. I'm pretty sure this had a 241DLD behind it. Does anyone know if the input shafts are interchangeable from the 241DLD and the 241DHD? I have that 241DHD behind the 47rh that will accept a speed sensor. I'd like to use it since my 10.25 rear doesn't have one.
Re: Ford project
Postby dazedandconfused » Tue Mar 03, 2015 5:36 pm
Dropped the Cass off today at the welder. He said come back tomorrow and it will be done. A buddy of mine found me some dually front hubs and even went and got them for me.
Re: Ford project
Postby ellis93 » Wed Mar 04, 2015 4:34 am
Be sure to post up a pic of the weld. I would like to see just how terrible my cast welding is compaired to someone else's :lol:
Re: Ford project
Postby dazedandconfused » Wed Mar 04, 2015 7:28 am
You know me I always take pics. Lol
Re: Ford project
Postby dazedandconfused » Wed Mar 04, 2015 5:28 pm
Removed the broken bolts from the bell housing today. I also cleaned, sand blasted and painted it and the tail housing.
Re: Ford project
Postby dazedandconfused » Thu Mar 05, 2015 9:44 am
So I got off work finally and picked up my trans case. It looks good to me and I'll be ordering my parts later. I'll take it to work tomorrow to sandblast, clean and paint.
Last edited by dazedandconfused on Tue Mar 10, 2015 5:07 pm, edited 1 time in total.
Re: Ford project
Postby dazedandconfused » Sat Mar 07, 2015 4:58 pm
I made a little progress on the donor today.
Re: Ford project
Postby oldestof11 » Sun Mar 08, 2015 5:40 am
Looking good Andy!
Re: Ford project
Postby dazedandconfused » Sun Mar 08, 2015 5:44 am
I'm running out of space. Everything to the left of the pic in the barn is Dodge Drive train. I've thought about trying to shorten that 99 frame and stick my 83 body on it. I don't know if it will be worth the work.
Re: Ford project
Postby dazedandconfused » Mon Mar 09, 2015 5:20 pm
Blasted and painted trans case. My rebuild kit minus my shim set showed up today. I also have everything loose on the engine except motor mounts so its ready to come out.
Re: Ford project
Postby PToombs » Mon Mar 09, 2015 5:36 pm
Andy, what color is the interior?
Re: Ford project
Postby dazedandconfused » Mon Mar 09, 2015 5:43 pm
Grey Pete. The driver side seat is trash but rest is pretty nice.
Re: Ford project
Postby PToombs » Mon Mar 09, 2015 6:03 pm
Ah poop. It's newer than '98.5 too. I need a tan door panel for my '97. During my mirror fiasco I broke 4 or 5 of the tabs the Christmas trees hook to because it was so cold when I was trying to pull the panel.
Re: Ford project
Postby dazedandconfused » Sat Mar 14, 2015 4:56 pm
Another day, another mess. Pulled cab and steam cleaned everything today including the Ford frame.
Also got my tools and shims so time to build the NV4500
Re: Ford project
Postby dazedandconfused » Tue Mar 17, 2015 5:05 pm
So I picked up a bigger bearing splitter tonight. I have the main shaft 95% apart just couldn't find my 3 jaw puller. It looks like I'll have to buy a input shaft. The bearing spun on the shaft a good bit and it has blueing from getting hot.
