coil over shocks
Re: coil over shocks
Postby 1992gen1_fan » Tue Mar 31, 2015 8:03 am
Well crap lol. Yea my truck has the 6" blocks under Tue rear springs. Maybe I could just use them on the front or something since they're ordered already and should be here any day..
1992gen1_fan
Postby 1992gen1_fan » Tue Mar 31, 2015 8:23 am
Looks like what I need are around 28.5" ext length and these 58496 will be 21.250" extended length
1992gen1_fan
Postby cougar » Fri Apr 03, 2015 9:38 am
1992gen1_fan wrote:Looks like what I need are around 28.5" ext length and these 58496 will be 21.250" extended length
The 58496 is for the front, not the rear.
01 2500 "the work truck".
cougar
Postby 1992gen1_fan » Fri Apr 03, 2015 7:03 pm
Ok thanks.
1992gen1_fan
Postby 1992gen1_fan » Fri Apr 03, 2015 7:10 pm
I found some shocks for the rear. Monroe 58571, they're listed for 81-93 W250 trucks but I assume its for the the ones with the shorter lift blocks like non I/c ones because they are just a couple inches shorter extended. I might be able to lower the upper shock mounts though.
I'm going to let the 'ol piggy bank recoup for a bit and get a set ordered unless I find something different.
1992gen1_fan
Postby cougar » Sat Apr 04, 2015 11:29 am
Those were for the 2wds. In my search I haven't found one for the rear. There is an option though, a coil spring that clamps around the tube of your current shock. Tried them on a heavy old car before with good success, but never on a truck. The other option is air shocks.
cougar
Postby Remps » Sat Apr 04, 2015 12:42 pm
I have shocks off the back of a 02 super duty 4x4 on the back of my D250. Just sayin shocks off a different application may work as well.
Postby 1992gen1_fan » Sat Apr 04, 2015 2:24 pm
Ok, well I might just might make a upper mount lowering bracket. Would that hurt anything??
1992gen1_fan
Postby cougar » Sat Apr 04, 2015 3:03 pm
The travel of the shock vs the travel of the suspension? Not enough is just as bad as too much. Somethin is gunna break.
cougar
Postby 1992gen1_fan » Sat Apr 04, 2015 8:34 pm
Ok thanks, yea wouldn't want to bottom them out :shock:
1992gen1_fan
Postby Tacoclaw » Sat Apr 04, 2015 8:54 pm
I don't know what kind of flexing you all are doing, but there's no way my truck is moving it's shocks the full length of travel.
Smear some grease around the shock shaft, drive/tow around, and see where it wipes it to, that'll give you your collapsed bump. Then jack/pick up the hitch and measure how far it droops. If you're just driving/towing then I doubt you're gonna need full travel.
Postby 1992gen1_fan » Sun Apr 05, 2015 10:16 am
I don't do any serious off road with the truck or anything but I do load the bed down heavy at times.
1992gen1_fan
Postby cougar » Mon Apr 06, 2015 8:15 am
Must be nice having good roads, no such luck around here. Shocks and tires have a short life up here.
cougar
Postby 1992gen1_fan » Mon Apr 06, 2015 4:42 pm
cougar wrote:Must be nice having good roads, no such luck around here. Shocks and tires have a short life up here.
Some of the roads here aren't great. Especially the dirt roads and county black top roads. Half of my daily trip is basically non stop pot holes and washboards. Some days the question of "why do I use a W350 as a daily driver" crosses my mind.
1992gen1_fan
Postby 1992gen1_fan » Sat Apr 18, 2015 7:41 am
I got those shocks I bought (58496) installed on the front of my truck. It turns out they needed changed anyway so worked out great. It gained 1/2" lift in the front with the new ones 8) .
Still need some for the rear axle.
1992gen1_fan
