Cummins/82 C10
Re: Cummins/82 C10
Postby Tacoclaw » Fri Apr 17, 2015 7:22 pm
Buttjealous.
Re: Cummins/82 C10
Postby fatty » Fri Apr 17, 2015 7:36 pm
ellis93 wrote:
fatty wrote:I'd complain too if I was forced to wear homo clothes. Poor thing.
You don't look in the mirror often do you? :lol:
You'll have to try a lot harder than that to offend me. I've got a pretty thick skin, I have four older brothers. :D
Re: Cummins/82 C10
Postby ellis93 » Fri Apr 17, 2015 7:41 pm
Oh I figured.....Pete is the one worried :lol:
Hey I'm gonna crack jokes and can take them ......hell,I have to,otherwise I'd have burnt this suck azz truck to the ground :lol:
Re: Cummins/82 C10
Postby ellis93 » Sat Apr 18, 2015 6:17 pm
I worked like a Hebrew slave all day and did not manage to get it in the truck.
I have had to make my throttle linkage from the p pump stuff,basically used the bell crank and braket and modified it to work with the ve pump using some little heim joints.
Also rigged up a bypass regulator and made up the fuel supply to work with the electric pump. I plan to set that at 12psi and then figure out how to use the boost reference the reg has to increase the pressure as I build boost.
All I like from installing it is the rockers installed and set,then do whatever I need to with the valve cover. I would like the whole mess buckled up before I shove it in the hole.
Before I put the body back together I plan to at least hear it run....since the pump is my first to build.
Re: Cummins/82 C10
Postby dazedandconfused » Sun Apr 19, 2015 7:13 am
Hopefully this is the last time you have to do this.
Re: Cummins/82 C10
Postby ellis93 » Sun Apr 19, 2015 7:56 am
I hope so Andy. I really do.
Re: Cummins/82 C10
Postby ellis93 » Mon Apr 20, 2015 10:25 am
Figured I'd throw up a crapy pic so yall could see the junk I've thrown together.
A bunch of rigging.....that is what is there. Hopefully I'm back on it tonight.
Re: Cummins/82 C10
Postby ellis93 » Mon Apr 20, 2015 7:31 pm
I just can't seem to get this thing in the damn truck :mad:
I got the turbos switched over (that was a PITA with the nuts being galded on the hy) and bolted on the mounts. Then moved on to the trans cooler mounted and modified (used the 2001's,it's smaller). Moved on to the valve cover.....I cut the D O D G E off and tried stripping the paint with aircraft remover only to have the stuff turn to jelly on me. The paint must be some kind of powder coat or something. I've never had any enigne paint do quite like that. Whatever.....it pretty much finished off what time I had.
Re: Cummins/82 C10
Postby Tacoclaw » Mon Apr 20, 2015 7:56 pm
If this was me, it would already be running and doing laps around the block with no front clip. The only reason it's not in the truck is your OCD. :P
This is a mile from my house, I had to solder the radiator afterward because I left the core support loose and it got in the fan. :lol:
Re: Cummins/82 C10
Postby ellis93 » Tue Apr 21, 2015 11:16 am
I'll admit....I have a little of that. If it's supposed to be a certain way that's how I want it. I won't be running around organizing other people's stuff :lol:
I killed the dodge lettering at lunch,and painted it up.
I think it'll look good under that silver hood ;)
Re: Cummins/82 C10
Postby PToombs » Tue Apr 21, 2015 4:48 pm
Spark plugs go in those holes? :lol:
Re: Cummins/82 C10
Postby Tacoclaw » Tue Apr 21, 2015 5:24 pm
Chrome don't get you home. :safe:
Re: Cummins/82 C10
Postby ellis93 » Tue Apr 21, 2015 6:15 pm
No it don't Levi,but at least it'll be pretty when I check the oil :lol:
Pete.....I've tried that and they just won't go :scratch: :lol:
Progress finally!
The bottom is buttoned up and I'm piecing the fuel,ps,and cables together.
I'm liking the red.
Re: Cummins/82 C10
Postby ellis93 » Wed Apr 22, 2015 6:27 pm
Hot Damn! It's alive!!!!
https://www.facebook.com/ellis.fortenbe ... 880434551/
I'm loving the noise and the fact the pump works is amazing to me lol
Re: Cummins/82 C10
Postby RCCUMMINS89 » Wed Apr 22, 2015 6:38 pm
Sounds like a 24 valve.
Mine is still not running.................gay.
Users browsing this forum: No registered users and 62 guests
