Cummins/82 C10
Re: Cummins/82 C10
Postby Remps » Fri Apr 24, 2015 6:34 pm
Have you tried it without a fuel pin, or smoke screw all the way down? The little slide pin pops out into the fuel pin bore when you hit the throttle, looking into the pump with afc top off? That's all I can think of, I've never built a pump. That 24 valve looks good in there btw.
Re: Cummins/82 C10
Postby ellis93 » Fri Apr 24, 2015 6:55 pm
I have not pulled the pin but the smoke screw was all the way down along with the star wheel. Ike thinks it's the slide ring....I guess. His reply was "time to pull the pump" :lol:
It'll be coming off in the am.
Re: Cummins/82 C10
Postby ellis93 » Sat Apr 25, 2015 8:24 am
Think I found the problem. The dang shut down lever is out of adjustment.
Least I hope that's all it takes to make it work right. I've looked at every thing else,compared with the original pump from the dodge and it all looks good.
We'll see I guess. Could this be the reason it was/seemed slow to rev up?
Re: Cummins/82 C10
Postby oldestof11 » Sat Apr 25, 2015 8:47 am
I would think so. It wasn't allowing the collar to full close the spill port. This would mean low power, slow rev...
Re: Cummins/82 C10
Postby ellis93 » Sat Apr 25, 2015 12:45 pm
Well that's what it was. It's running but needs tuning. I'll update when I have time to Dick with it again
Re: Cummins/82 C10
Postby dazedandconfused » Sat Apr 25, 2015 2:49 pm
Glad to hear.
Re: Cummins/82 C10
Postby ellis93 » Sat Apr 25, 2015 6:22 pm
Did a little more tuning on the afc and got the low speed power where I like it. Now it's just the top end/high rpm that is screwing it up. It is throwing the fuel....I see the brownish black haze,just don't feel the go.
I'm thinking when I build the pump I might have fudged up and installed the non intercooled timing spring.....it was longer and stiffer than the intercooled. So maybe it's holding off my advance?
Re: Cummins/82 C10
Postby ellis93 » Sun Apr 26, 2015 6:56 pm
A fuzz more tuning done and I actually got a little more travel out of my throttle. It woke it up a little more but.....I believe there's more to be had. I feel the timing is still funny
Re: Cummins/82 C10
Postby ellis93 » Sun Apr 26, 2015 7:52 pm
By the way......does this tread have the aids or something..... :?
Re: Cummins/82 C10
Postby RumbleFish » Mon Apr 27, 2015 4:47 am
Worse.....it has a bowtie!
Glad to see youre making some progress on it.
Re: Cummins/82 C10
Postby ellis93 » Mon Apr 27, 2015 6:04 am
RumbleFish wrote:Worse.....it has a bowtie!
I'll take that :lol:
Least it has a EV in it now 8)
V dang E.
Re: Cummins/82 C10
Postby dazedandconfused » Mon Apr 27, 2015 7:29 am
What the hell is an EV?
Re: Cummins/82 C10
Postby ellis93 » Mon Apr 27, 2015 7:51 am
VE damn it. I hate my phone :roll:
Re: Cummins/82 C10
Postby dazedandconfused » Mon Apr 27, 2015 8:06 am
:lol: :lol: I thought maybe your dyslexia was kicking in.
Re: Cummins/82 C10
Postby Tacoclaw » Mon Apr 27, 2015 10:27 am
Paint it Detroit Green and I'll come hang out more. :P
