Cruise control
Cruise control
Postby Ryker Carruthers » Fri May 01, 2015 7:17 am
Okay so here a few months ago I decided to try to get my cruise to work, the clock spring was worn out so I traced the wires to the dash and put a toggle switch for the set, so to set cruise flip it on, then off. It will hold the speed on flat ground, and give it throttle to maintain speed up hill. But as you reach the top of the hill it will not let out of the throttle, it will keep gaining and not come down until you cancel. Any ideas?
Ryker Carruthers
92 W250 g360 3.55's
Ryker Carruthers
Re: Cruise control
Postby PToombs » Fri May 01, 2015 4:52 pm
Sounds like a valve is sticking open. Find an FSM to troubleshoot it or find another actuator. They are almost all the same for those years, from a van, truck, or whatever. You may need to change the cable over though.
Re: Cruise control
Postby Ryker Carruthers » Mon May 04, 2015 11:32 am
10-4 thanks pete
Ryker Carruthers
92 W250 g360 3.55's
Ryker Carruthers
Re: Cruise control
Postby thrashingcows » Mon May 04, 2015 8:29 pm
This is what mine does as well. I have swapped on several different servo's...no change. Swapped steering wheel switches...no change. Swapped brake light switches...no change. Done every test the FSM says to do (twice)...everything tests perfectly. No idea why it won't work properly.
thrashingcows
Re: Cruise control
Postby Ryker Carruthers » Tue May 05, 2015 10:44 am
I forgot to mention the other weird thing it does, I took off my steering wheel buttons awhile back, put the cruise control switches on toggles. My clock spring was gonzo. But occasionally when I do play with the cruise, to set flip the set toggle to on then back off, sometimes it will mat the pedal right away and she goes. Scared the sthi out of me the first time it happened. Does that info help at all?
Ryker Carruthers
92 W250 g360 3.55's
Ryker Carruthers
Re: Cruise control
Postby PToombs » Tue May 05, 2015 4:33 pm
Mine hits hard too, when I hit the "set" or " resume" buttons it will mat the throttle for a second or 2 and then settle back as it gets control.
Ryker, are you using momentary switches?
Re: Cruise control
Postby Ryker Carruthers » Fri May 08, 2015 10:17 am
No Pete I am not, So for set you have to flip on then off. It was a late night deal i wanted it to drive to illinois but still didn't work in the end.
Ryker Carruthers
92 W250 g360 3.55's
Ryker Carruthers
Re: Cruise control
Postby RumbleFish » Fri May 08, 2015 11:09 am
Go to the help aisle at the parts store and get a gm cruise stalk. Wire it up instead of toggles. Done.
Re: Cruise control
Postby thrashingcows » Fri May 08, 2015 11:20 am
RumbleFish wrote:Go to the help aisle at the parts store and get a gm cruise stalk. Wire it up instead of toggles. Done.
Been thinking of doing that as well. At least if the problem persists after that I know it's not the switches, or the clock spring.
thrashingcows
Re: Cruise control
Postby Ryker Carruthers » Sat Jun 06, 2015 6:48 am
Switches on the wheel gone. Clocks spring was shot and wires broken in colum.
Ryker Carruthers
92 W250 g360 3.55's
Ryker Carruthers
Re: Cruise control
Postby PToombs » Tue Jun 09, 2015 5:00 pm
Were you typing this at breakfast? :lol: I forgot all about this problem we were so busy working on the other one.
Re: Cruise control
Postby RumbleFish » Tue Jun 09, 2015 6:40 pm
Im gonna say he was, cuz I checked in here at breakfast and this post was about 4 minutes old at the time.
I also forgot to show him my gm cruise dealy that bypasses the clock spring.
Re: Cruise control
Postby Ryker Carruthers » Tue Jul 07, 2015 3:58 am
Yeah I guess other things were a little more urgent..
Ryker Carruthers
92 W250 g360 3.55's
Ryker Carruthers
Re: Cruise control
Postby cougar » Sat Aug 29, 2015 11:07 am
Mine was intermittent as well. Some times did the rabbit launch runaway, sometimes never stabilize speed, sometimes not disengage or very slowly disengage, sometimes not work at all or work perfectly.
How I fixed it? Removed the battery, remove the cover from the PCM plug, pushed each socket onto the PCM pin, reinstalled cover, reinstalled battery. Not only got my cruise control back, I also got my TPS OD control back.
01 2500 "the work truck".
cougar
Re: Cruise control
Postby CumminsPower59 » Tue Sep 01, 2015 10:35 am
The cruise control in the 91.5-93 trucks can be taught how to act. There is actually a procedure to re-learn it to work how you want it to. If you set it and take your foot off the accelerator, it will catch itself and hit the trottle. You can get it to not do that anymore if you reset it. I'll dig around and see what I can come up with. For some reason I am thinking its in the FSM for some reason.
Return to Electrical
