NP205 rebuild kit
NP205 rebuild kit
Postby Remps » Mon Jun 15, 2015 3:25 pm
Who sells a complete rebuild kit for a np205? 4wd hi still works, 4 lo sounds really rough, 2wd still drives fine. Front output has a good 1/2" side to side and up and down play.
Re: NP205 rebuild kit
Postby matthewh » Mon Jun 15, 2015 4:39 pm
Zbag had a nice kit I bought when i rebuilt my NP205 on my M37 project. Had all the gaskets, bearings, etc. Iirc it didn't have all the shims I needed for the idler gear, but I had some used ones out of another parts tcase.
I was told eBay has cheaper ones, but never used them so cant say yes or no to quality
matthewh
Postby Remps » Mon Jun 15, 2015 8:14 pm
Is there replacement gears available as well, if they need replacing?
Postby matthewh » Mon Jun 15, 2015 11:39 pm
Not positive they have every gear, but I'm sure they do. They had a new input gear, was under $80 I believe.
I only bought the input to build a married 205 out of a divorced 205 I had laying around.
matthewh
Postby thrashingcows » Tue Jun 16, 2015 10:24 am
The NP205's a re pretty bullet proof. I highly doubt you will have any problems with the gears. When I rebuilt mine, and converted it from 23 spline to 29 spline, I used a kit bearing and seal kit form E-bay. Can't recall who it was from, but it has been OK. The paper gaskets were super thin though, and I didn't put any additional sealant on them, so I have some leaks from that. But it used Koyo bearings, and it has functioned well so far.
thrashingcows
Postby TRACTJDS0428 » Sat Jun 27, 2015 3:55 pm
I used a temkin kit from summit racing. Had everything I needed. Found the part number from rock auto and they were out of stock, so I entered the part number on google and summit had it.
1993 Dodge W250, Cold Air, Borg Warner 60/68 turbo. 4" down pipe. 5x14 Injectors. Pump Mods. Airdogg II 165, Billet Fuel Tank Sump. ATS valve body, ATS converter, Pyro, Fuel pressure, Boost and Trany temp gauges. 72" T-Rex Products Long Bars. 285/75-16 Toyo Open Country M/T's. Western 9Ft MVP Ultra Mount V-Plow.
TRACTJDS0428
Postby dds78910 » Tue Jul 07, 2015 8:23 am
http://quad4x4.com/
Seems to be a good site for 205 parts and info
dds78910
Postby lz69 » Mon Jul 13, 2015 12:32 am
Being as your in Canada I would try North West Fabworks http://www.northwestfab.com/Transfer-Case-Rebuild-Kits_c_73.html
Make sure your rebuild kit has a front input seal and dodge round pattern gasket. I bought a kit off ebay and it was missing these two
lz69
Return to Transmission
