bhaf wanted
bhaf wanted
Postby 93cummins89 » Sat Jul 25, 2015 11:24 am
any one got any advice on how to put in a bhaf and what to use
93cummins89
Re: bhaf wanted
Postby RumbleFish » Sat Jul 25, 2015 1:22 pm
Wix 42790 is the filter everybody uses.
Re: bhaf wanted
Postby RCCUMMINS89 » Sat Jul 25, 2015 1:23 pm
BHAF, 5 t-bolt clamps ,2 45 degree elbows, 16" piece of 4" exhaust pipe, and a 3" piece of 4" exhaust pipe, and then a clamp or mount of some sort. I'm not posting the next link for advertising, but more for you to see what it involves in the picture.
http://thehungrydiesel.com/BHAF-Intake- ... intake.htm
Re: bhaf wanted
Postby jethro » Sun Jul 26, 2015 11:25 pm
I just got a version from NAPA-
4 inch inside the rubber endpiece-
I am going to try using silicone SCAT hose - which is a 2 layer of fiberglass impregnated silicone with a steel wire spring
molded between the layers. Used in aircraft for carb heat air and hot or cold air ducts. 4 inch is about 15$ a foot.
I think 3 feet should do it ! It bends easily but doesn't collapse easily because of the wire. Rated to 500F.
get at aircraft spruce, wicks, chief aircraft supply, airparts, ect.
Going to try to build an aluminum box of some kind fro a filter housing. Not sure yet where to go with the inlet.....
Tim
jethro
Re: bhaf wanted
Postby 93cummins89 » Mon Jul 27, 2015 4:18 pm
sweet thanks guys
93cummins89
Re: bhaf wanted
Postby RumbleFish » Tue Jul 28, 2015 8:23 am
If youre going to napa then youll want a 2790
Re: bhaf wanted
Postby CumminsPower59 » Tue Jul 28, 2015 8:50 am
Damn, those things have gotten stupid expensive. $98 from Napa and $86 from Oreilly's.
I think I paid $65 for mine...but that's been a few years ago...but I think it's a Donaldson...
Re: bhaf wanted
Postby CumminsPower59 » Tue Jul 28, 2015 8:55 am
If you can buy online, I would try checking all the part numbers...I found some as low as $60 shipped.
I did some digging anyways...
Technical specs for the regular one...
https://catalog.donaldson.com/productDe ... 504#tabs-2
Seen this too, kinda nifty and it has a high CFM like the standard BHAF...
https://catalog.donaldson.com/productDe ... uId=s63522
Although long...one could very well make a cold air intake off of it somehow...and its just about the same price, at around $85-90.
Re: bhaf wanted
Postby RCCUMMINS89 » Tue Jul 28, 2015 9:43 am
CumminsPower59 wrote:Damn, those things have gotten stupid expensive. $98 from Napa and $86 from Oreilly's.
You can buy them online for about $56 ;)
Re: bhaf wanted
Postby CumminsPower59 » Tue Jul 28, 2015 10:23 am
I looked and couldn't find much less with shipping added for less than what I posted...
Geeze, I'm batting .000 today :?
Re: bhaf wanted
Postby RCCUMMINS89 » Tue Jul 28, 2015 11:04 am
We're $61.99 shipped on the site, Ike.
Re: bhaf wanted
Postby CumminsPower59 » Tue Jul 28, 2015 1:29 pm
Well, fooey! :oops:
That's a pretty good deal my friend 8)
Re: bhaf wanted
Postby 93cummins89 » Tue Jul 28, 2015 3:35 pm
why not just a john deere or semi truck filter?
93cummins89
