aftermarket cruise on a 85 cummins swap
Postby steveinil » Fri Jul 31, 2015 9:26 am
truck has an engine from a 90 and nv4500 from a 2000 dont have the truck yet hopefully buying it sat. but was wondering about aftermarket cruise the guy has a kit he bought somewhere he said he will throw in on the deal but never installed it do they work ok on a swap like this? no idea what brand it it
steveinil
Re: aftermarket cruise on a 85 cummins swap
Postby RumbleFish » Sat Aug 01, 2015 7:13 am
I had a 91 with aftermarket cruise and it worked well enough. I cant imagine it would be too much different ina swap like that. I think it was made by rostra?
Postby thrashingcows » Sat Aug 01, 2015 9:27 pm
You are probably better to use an aftermarket set-up. The OEM electronic cruise set-up can be very problematic.
Someone mentioned once about using a cruise set-up from a mid to late 80's GM? They had a stand alone controller that required a VSS signal, ignition power and a ground, and that is about it?
thrashingcows
Postby CumminsPower59 » Thu Aug 20, 2015 10:20 am
Postby thrashingcows » Sat Aug 22, 2015 9:48 am
CumminsPower59 wrote:http://www.4btswaps.com/forum/showthread.php?40050-Simple-stand-alone-cable-opperated-cruise-control
http://www.4btswaps.com/forum/showthrea ... ow-To-Info
Thank you! :D
thrashingcows
Return to Electrical
