New engine is back.
Re: New engine is back.
Postby PToombs » Sat Aug 22, 2015 5:23 pm
RCCUMMINS89 wrote:Pulled the valve cover this morning. Adjuster backed off, and the bridge fell off.
You'll have that with those overvalved engines. ;)
Postby RCCUMMINS89 » Sat Aug 22, 2015 5:32 pm
Postby cmauz61 » Sun Aug 23, 2015 1:41 pm
Sounds like you got lucky!!! i was def thinking you dropped a valve.. I am about to have my motor pulled studed and girlded with all new parts (a little dif than your build) i hate reading about problems after its all done.. i would blow up :bom:
1992 dodge w250 12v
4" turbo back exhaust, denny t fuel pin, 12mm pump cranked, 4,200 rpm spring, afe intake/filter, egt gauge, boost gauge.
cmauz61
Postby RCCUMMINS89 » Tue Sep 01, 2015 2:31 pm
I'm officially fed up. Still getting air in the system.
I've added a sump, replaced all the lines, fuel filter assembly (even by passed it to check), all the lines all the way to the injection pump. Pump the lift pump manually and no bubbles in the system, clear to the injectors... start it up, foamy fuel at the injectors.
Postby PToombs » Tue Sep 01, 2015 5:41 pm
Piston LP right? Check the seal on the large nut the inlet fitting goes into. I'm sure you know, but there are 2 pistons in it, the 1 for the hand pump, and the one for the engine driven pump. I'm thinking that the engine driven one is sucking air, it may not be at the inlet seal either, maybe it's the shaft seal to keep oil out or something like that?
Either that or the LP is drawing too hard and causing cavitation when running? I'm not sure how with big lines but it's all I can think of!
Postby RCCUMMINS89 » Tue Sep 01, 2015 6:00 pm
I've replaced it, still nothing changed. I've also cracked the inlet fitting to the injection pump while running..... no bubbles there.
Ellis on the bookface mentioned dv not sealing correctly.... maybe? But heck they are all brand new, and I would think it would be not consistent between cylinders.
I'm sure it is something simple, and I'm just not seeing it.
Postby Douglas » Wed Sep 02, 2015 11:56 am
I'd be tempted to try an off-board fuel system and an electrical pump. Jug of #2 and a Carter 4601...and be really careful wid the line seals...:)
or maybe something cheaper like: http://www.aliexpress.com/store/product ... 53502.html
cheers,
Douglas
1991 D250, 727 and 16cm H1C.
Douglas
Postby RCCUMMINS89 » Wed Sep 02, 2015 12:00 pm
It is not sucking air pre injection pump. It has been tested over and over again.
Postby RCCUMMINS89 » Wed Sep 02, 2015 12:21 pm
I'm going to pull the delivery valves and re check them and the crush washers. Talking to both of my pump builders.... it is acting like a delivery valve issue.
In the mean time, it is no longer getting air.....yet acts almost the same. High rpm it is smooth......idle it is almost perfect. Off idle it has a noticeable wobble to the engine. Like the cylinders aren't being fed evenly.
This is why one is supposed to bench a pump when parts are replaced.
Postby ellis93 » Wed Sep 02, 2015 5:44 pm
If it's getting better......why not just run it awhile longer. Maybe like I said,something is lapping in. I know things are not supposed to do that inside an injection pump but seems/sounds like that's what's happening.
Postby RCCUMMINS89 » Wed Sep 02, 2015 5:52 pm
I'm slowly putting it back together. I have to finalize the mount of my remote filter set up. then rig up my shut off cable and throttle cable and then I'm going to drive it. Oh yea, I have to rig up my coolant temp gauge too.
Postby RCCUMMINS89 » Mon Oct 12, 2015 5:18 pm
As an update...........September was archery season for elk.......means no working on a vehicle.
Today I finally said the heck with it. Went out and decided I was just going to drive it. As without air, it still had a sustained rpm miss in the off idle to mid rpm.....above that was fine.
After 20 zip ties later I could red neck her down the road......drives amazing! I can't feel that miss, though sometimes I think I may hear it under the hood (though not through the exhaust). Once warmed up I virtually can't even make it haze. Has the "stock 1st gen start up puff" and that is it.
I'm going to finish installing gauges, make throttle linkages and what not, put the hood on and drive it for a few days and see how it goes.
Postby ellis93 » Mon Oct 12, 2015 6:49 pm
You still using the 7hole vp tips on the bodies? What are the pop pressures set at on them?
Postby RCCUMMINS89 » Mon Oct 12, 2015 8:09 pm
7x.011 micro blind sac vp injectors........then honed out 30% over. Pop set at 255 bar.
Remember that was one of the biggest reasons I chose the vp head. That, along with a 182/214 cam, and raised compression (slightly) I was hoping to get the same peak hp, but a clean running truck.
I only took it for a short drive, but it seems all of these things have been perfectly balanced, and the result is even better than I expected. But again........short drive.
Postby ellis93 » Mon Oct 12, 2015 8:30 pm
I've got to get my cores to you to have honed. I'm itching for some more go.
