New here, with my 1st gen Cummins powered '78 Bronco
Stop in and say hi
Postby Copperman » Thu Aug 27, 2015 4:11 pm
Hi, this looks like a cool forum, so I joined up.
In 2009, I built a 1978 Bronco with 1991 Cummins 6BT power, C6 auto that I had specially built by Dynamic Racing Transmissions with 1200 rpm converter, and the truck is lifted 9" with everything having been replaced/rebuilt on the '78 chassis. The truck only weighs 5200 lbs, so it's very light for a diesel, and thus, it's pretty fast. lol I get 17 city/23 highway mpg with it, and it's been my DD for 35k miles, I love driving it. Of course I want more power, though.
1991 Cummins 6BT - Ford blue, of course. :D
Billet aluminum bellhousing adapter plate from Destroked
Matching flexplate, also from Destroked. SFI approved for competition. (It's VERY strong)
Just bought some sheet metal for it, I am going to weld in new quarters and door skins hopefully before winter
Copperman
Re: New here, with my 1st gen Cummins powered '78 Bronco
Postby oldestof11 » Thu Aug 27, 2015 5:46 pm
NICE!
I do wonder what your axle ratios are. The C6 doesn't have OD does it? I don't think Ford had an overdrive trans until the AOD...
Postby RumbleFish » Thu Aug 27, 2015 6:10 pm
Half ton axles? I too like to live dangerously. Lol. Nice rig. I love 2 door suvs. Makes me want another ramcharger.
Postby Copperman » Thu Aug 27, 2015 7:59 pm
My axle ratio is 3.50, with the 35"(after tomorrow, 37") the ratio is the equivalent of a car with regular tires and 3.00 gears. I am eyeing the 6L80E transmission for a possible swap at some point. I am liking it's specs so far.
As for the 1/2 ton axles, they do hold up pretty well in a light truck, even with Cummins power. I put a trac-loc posi up front, so the axles have it easier, and rebuilt everything. So far so good. The rear of course is a 9" axle, and those are pretty durable. Even the stock 31 spline axles have held up since 2009! Lots of hole shots with the truck, too. lol
https://www.youtube.com/watch?v=ZdN8E9cllus
Boost launch, outside view
https://www.youtube.com/watch?v=t6Os0e3ebA8
Same boost launch, inside view.
Still no intercooler on it. 3200 gov spring, pump turned up as high as possible, denny T fuel pin, pump timing advanced some. Everything else is bone stock. I want to upgrade the turbo and add an intercooler next! I want zero smoke at full throttle.
Copperman
Postby ellis93 » Thu Aug 27, 2015 8:01 pm
oldestof11 wrote:NICE!
Nope it's a 3spd. A VERY tough 3spd. That cummins would destroy an AOD.
Postby ellis93 » Thu Aug 27, 2015 8:02 pm
Copperman wrote:My axle ratio is 3.50, with the 35"(after tomorrow, 37") the ratio is the equivalent of a car with regular tires and 3.00 gears. I am eyeing the 6L80E transmission for a possible swap at some point. I am liking it's specs so far.
Cool truck! I don't see many old broncos down here,good to know some are still kicking.
Postby thrashingcows » Fri Aug 28, 2015 1:52 am
Very cool truck...and that outside boost launch....sure gets up and scoots! ;) :mrgreen:
thrashingcows
Postby Copperman » Fri Aug 28, 2015 6:12 pm
Thanks for the compliments! I consider my bronco to be a blood brother to the dodge cummins pickups. Not only is the engine from the 1 ton dodge, but several other dodge parts I needed for the engine swap literally bolted right into my truck. I'm using the dodge alternator, p/s pump, throttle pedal and cable assembly, brake prop valve, part of the instrument cluster lighting, and some other pieces I can't think of right now. lol
Copperman
Postby oldestof11 » Fri Aug 28, 2015 7:26 pm
So it is a Dodge with Ford sheetmetal. :lol:
Postby Copperman » Fri Aug 28, 2015 8:06 pm
oldestof11 wrote:So it is a Dodge with Ford sheetmetal. :lol:
Well, maybe not quite that much, but it's a lot. lol
Copperman
Postby cmauz61 » Fri Aug 28, 2015 9:37 pm
sweet ride man. It looks like it'd be a lot of fun in the mud!!
1992 dodge w250 12v
4" turbo back exhaust, denny t fuel pin, 12mm pump cranked, 4,200 rpm spring, afe intake/filter, egt gauge, boost gauge.
cmauz61
Return to Welcome
