CumminsPower59 wrote:I was going to comment earlier, but I wanted to see how the brake cleaner worked out. From my previous experience with friction surfaces, once they get some sort of petroleum product in them, not much is going to get it back out completely. I've gone through can after can to try and get truck brake linings cleaned up so the thing would work good enough to get to where I need it to go, but even then, the friction surfaces were pretty much FUBAR. I know, I know...apples to oranges...
You could always pull it out and blast it again, get it as dry as possible. May end up working....? If it were my pile, I'd give 'er a try
