s357/s475 twins questions
Postby rollieD250 » Tue Sep 29, 2015 4:23 pm
Truck should be back from the body shop pretty soon....and i sent out my rocker pedistals out to be machined so i can install the studs....long story short my goal is to ppump it and make it fast blah blah BUT in the mean time i want to know if the 57/475 twins are worth doing with my VE. I already have the 57 (super bee) installed on my truck...
What size sticks would compliment those turbos nicely? It is a 5 spd
How long should it last with just studs, no o/fire rings...am i wasting my time??
Just trying to make it fun while the VE lasts... Thank you guys
1992 D250
THD fuel pin, 3200 spring, 57/65/14, timing spacer, 3pc manifold, piston lift pump, ASA intake
rollieD250
Re: s357/s475 twins questions
Postby RCCUMMINS89 » Tue Sep 29, 2015 8:10 pm
What's your goal with the p pump?
Postby rollieD250 » Tue Sep 29, 2015 8:43 pm
5-600hp and 47rh swap, mainly to bolt on some slicks and see how fast i can go....cant do
It all one shot $$$$$ though
1992 D250
rollieD250
Postby rollieD250 » Tue Sep 29, 2015 8:44 pm
Also when i swap the ppump i will also fire ring that head and slap it on
1992 D250
rollieD250
Postby RCCUMMINS89 » Tue Sep 29, 2015 8:47 pm
5x16 or 5x18. That way when you p pump, you can just swap bodies and re use the new nozzles.
