hx40 60 62 14
hx40 60 62 14
Postby kyled19 » Wed Sep 30, 2015 6:17 pm
found a hx40 60 62 14 non gated for 300 and i think I can get it for even less than that will this work good on our trucks?
93 d350 extened cab dually dennyt stage 2, 3200 rpm gov spring, intake, 4 inch exhaust, he351cw, fass lift pump, and an a518. 4th gen seats
kyled19
Re: hx40 60 62 14
Postby CumminsPower59 » Wed Sep 30, 2015 6:40 pm
I run Super 40 variant, works well for me.
Re: hx40 60 62 14
Postby kyled19 » Wed Sep 30, 2015 9:12 pm
CumminsPower59 wrote:I run Super 40 variant, works well for me.
What are the specs on your super 40?
kyled19
Re: hx40 60 62 14
Postby RCCUMMINS89 » Wed Sep 30, 2015 9:40 pm
60/65/16 is the std. "super 40".
Re: hx40 60 62 14
Postby kyled19 » Wed Sep 30, 2015 10:37 pm
RC do you think this would be a decent turbo for the price? would i see a big improvement over stock? how do you think it would spool on the truck in my sig?
kyled19
Re: hx40 60 62 14
Postby RCCUMMINS89 » Wed Sep 30, 2015 10:51 pm
I'm personally not a fan of the hx40 turbos. Stock injectors.......go with an he351cw, or even an hx35 will clean up stock sticks.
Re: hx40 60 62 14
Postby CumminsPower59 » Thu Oct 01, 2015 3:35 am
RCCUMMINS89 wrote:60/65/16 is the std. "super 40".
Mine is the same, just out of something newer, it has one of those longer inlets on the compressor housing with sensor ports. It works for me, but if I had to do it again, like RC said, get a 351cw or HX35. It's kinda laggy, but I'm able to have it spooled around 1700-1800 rpms.
Re: hx40 60 62 14
Postby kyled19 » Thu Oct 01, 2015 6:40 am
How do you think the 351cw will do towing? Will it run hot? The heaviest I will tow is 14k and only occasionally not very often
kyled19
Re: hx40 60 62 14
Postby CumminsPower59 » Thu Oct 01, 2015 6:42 am
That I couldn't tell you...
Re: hx40 60 62 14
Postby kyled19 » Thu Oct 01, 2015 6:54 am
RC do you know how hot it would run?
kyled19
Re: hx40 60 62 14
Postby Remps » Thu Oct 01, 2015 10:26 am
What trans you run? What gears in the diff?
Re: hx40 60 62 14
Postby BILTIT » Thu Oct 01, 2015 11:45 am
kyled19 wrote:How do you think the 351cw will do towing? Will it run hot? The heaviest I will tow is 14k and only occasionally not very often
It runs pretty good.
I tow 12k and at 38-40psi in 4th gear (getrag) i can accelerate up a good hill and not go over 1300F (stock injectors and pump turned up).
This is the hill i am talking about:
Derek B.
BILTIT
Re: hx40 60 62 14
Postby RCCUMMINS89 » Thu Oct 01, 2015 4:50 pm
351cw is the coolest running turbo I have ever driven, towing.
Re: hx40 60 62 14
Postby kyled19 » Thu Oct 01, 2015 6:50 pm
Cool thank you for the info! I thought it would run hot because of the small exhaust housing! But if it runs cool sounds like a great turbo to run!!
kyled19
Re: hx40 60 62 14
Postby kyled19 » Thu Oct 01, 2015 8:57 pm
auto trans with overdrive and i think 4:10 in the rear not 100% positive
kyled19
