Upper 2WD Ball Joints
Re: Upper 2WD Ball Joints
Postby dazedandconfused » Thu Oct 01, 2015 2:05 am
The upper ball joints screw in they don't press in.
Postby Diesel » Thu Oct 01, 2015 12:13 pm
dazedandconfused wrote:The upper ball joints screw in they don't press in.
Good luck with that whole thing. After threading them in you will soon realize that they will not stay that way with the truck loaded down hitting a bump. So I got out the ole welder and made sure they won't move.
1991.5 D250 Intercooled A518
Diesel
Postby dazedandconfused » Thu Oct 01, 2015 2:31 pm
That's why you replace the upper arms
Postby Diesel » Thu Oct 01, 2015 4:28 pm
I bought new arms, new ball joints, put the new joints into the new arms, and STILL burned them into the arm. I'll just replace the arm if that upper joint ever needs replacing.
Diesel
