RCCUMMINS89 wrote:If you leave everything on the turbo stock.........you can leave the solenoid alone and the gate will open at 20 psi. Put 12 volts to it, and it'll open at 40psi.
Douglas wrote: I assume that the thing could be set to open at 30 psi with 6V to the coil?
PToombs wrote:Douglas wrote: I assume that the thing could be set to open at 30 psi with 6V to the coil?
Holy crap, I never heard an engineer assume before! You know what happens when you do that, right?
Users browsing this forum: No registered users and 84 guests
