dazedandconfused wrote:You can wire OD to a toggle switch and make it cone on when ever. All your doing is grounding the solenoid in the trans to engage OD. With 3.55 gears and a 27" tire my truck needed more rpm or a higher gear. I switched to a 3.25 with a 31" tire and it does a lot better up top. Since your only running 1/8th it may not affect you as much. Throw an external waste gate on and spray it.
dazedandconfused wrote:Didn't know you were dropping it in a Satellite. Pretty cool deal. How far back is it set in there?
