0-60 vids??!?!
0-60 vids??!?!
Postby spencerdiesel » Mon Nov 02, 2015 4:24 pm
Hey wasn't real sure where to post this but, who's got acceleration vids of their trucks? EGT shots, 0-60 ect...
Re: 0-60 vids??!?!
Postby BC847 » Mon Nov 02, 2015 5:22 pm
Re: 0-60 vids??!?!
Postby Tacoclaw » Mon Nov 02, 2015 7:49 pm
Re: 0-60 vids??!?!
Postby fatty » Mon Nov 02, 2015 8:29 pm
Here's mine. Mods are in the YouTube description.https://youtu.be/h9MVdn9lgXg
Re: 0-60 vids??!?!
Postby spencerdiesel » Tue Nov 03, 2015 2:40 pm
Awesome, ridiculous power to be seen on this thread! Thanks much, BC your truck looks awesome in the diesel power mag.
Re: 0-60 vids??!?!
Postby spencerdiesel » Tue Nov 03, 2015 4:47 pm
Hey RC you got any vids of the 24v motor?
Re: 0-60 vids??!?!
Postby spencerdiesel » Fri Nov 06, 2015 6:04 pm
BC, watched your 12.67s pass. Truly impressed. Have you ever got to stretch the beast's legs before? what were EGT's like :lol:
Re: 0-60 vids??!?!
Postby RCCUMMINS89 » Sat Nov 07, 2015 8:57 pm
I have no videos yet of the 24 valve engine. We are still working out bugs.
I've also got no vids of the old 12 valve, original engine. As a manual trans, big drive line angles, and 37" tires, I do not do off the line stuff...... I like things not to scatter.
Re: 0-60 vids??!?!
Postby spencerdiesel » Sun Nov 08, 2015 8:25 am
Not a problem, be neat to see a mild vid or two if you ever did them
Re: 0-60 vids??!?!
Postby RCCUMMINS89 » Sun Nov 08, 2015 9:53 am
Hopefully can. Not sure when it will be running again.
Back when we first put the engine in, it didn't pump oil Swapped the oil pump, pulled and looked at the mains....looked ok. After 250 miles it is being pulled due to a knock. Sounds to me like a rod knock. However, I feel that it will be a simple, quick fix.
Re: 0-60 vids??!?!
Postby spencerdiesel » Sun Nov 08, 2015 11:16 am
I'm sorry to hear that man. Was the oil pump just defective? Is there a thread you've got on the 24v motor I can go to?
Re: 0-60 vids??!?!
Postby RCCUMMINS89 » Sun Nov 08, 2015 1:57 pm
Thread? Not really. I didn't build the engine myself. I have an engine builder that I use. And apparently. Considering we swapped pumps and it immediately pumped oil.
Re: 0-60 vids??!?!
Postby spencerdiesel » Sun Nov 08, 2015 3:40 pm
Ok no big deal. I was just curious because some of my buds have told me they packed the pump with lubriplate/ grease (to prime it) before they installed, and it wouldn't pump oil. The thick lubricants didn't disperse and instead blocked oil flow. Just something I didn't know and figured others like me might find helpful.
Re: 0-60 vids??!?!
Postby fatty » Sun Nov 08, 2015 4:31 pm
This is a 0-70. Poor quality, it was shot with an iPhone then sent to my android.
https://youtu.be/WD68l0Hagio
Re: 0-60 vids??!?!
Postby spencerdiesel » Sun Nov 08, 2015 5:35 pm
Gah what a beast......does it break loose in 2wd when the turbo lights on damp pavement? Cuz it lights at about 30ish mph right?
Return to Competition
