Keeping IP alive w/stock lift pump
Postby spencerdiesel » Mon Nov 02, 2015 4:12 pm
Hey everyone, only mods are fuel pin and 366 spring. How much fuel is "ok" to run over stock, before diaghram pump can't keep enough fuel to the IP for longevity? I'll be getting 12 psi piston pump, but it'll be a little while. Can I turn my fuel screw in just a little?
Re: Keeping IP alive w/stock lift pump
Postby CumminsPower59 » Thu Nov 05, 2015 11:20 am
Get a fuel pressure gauge on it and see then. It's not hard to pull the stock lift pump down to 0psi with just pump mods (in my experience).
Postby spencerdiesel » Thu Nov 05, 2015 5:15 pm
Thank you.
Postby spencerdiesel » Tue Nov 17, 2015 6:02 am
I know I should get a gauge, but not feasible for the time being.
Truck doesn't "fall on its face", but piddles out noticeably at 2800 rpm.
I know VE's aren't high revvers, but is that a bit early? I promise eventually ill get a piston pump :roll:
Postby CumminsPower59 » Tue Nov 17, 2015 6:11 am
Sounds like you are out of fuel. Get a gauge on there. Cheaper than a injection pump.
Postby PToombs » Tue Nov 17, 2015 5:02 pm
Geno's garage has the banjo bolt tapped for 1/8th pipe for $7 or $8, and any pressure gauge will work to see what is going on. And old oil pressure gauge, boost gauge (I've seen them used), as long as you can read the pressure it will work for a temporary trouble shooting tool.
Postby spencerdiesel » Wed Nov 18, 2015 8:33 am
That's defiantly doable then.
Postby 1STGENFARMBOY » Mon Nov 30, 2015 9:53 pm
I have a $15.00 summit mechanical fuel psi gauge on my truck along with the banjo bolt Pete spoke of, works fine
Postby spencerdiesel » Tue Dec 01, 2015 7:01 pm
Great info, I like saving greenbacks. Ordered the piston pump from THD, 12 psi spring. Put 7'' fs1221 filter on. Just the bigger filter actually took 3 tenths off the 30-60 time. Previous wasn't clogged either, cut it open and just found a couple specs. Could the extra surface area aid in flow just like on an air filter?
Postby spencerdiesel » Wed Dec 02, 2015 3:57 pm
Pump came in, fingers are twitching
Postby spencerdiesel » Sun May 08, 2016 2:13 pm
Looking at the isspro R5604R mechanical gauge. I've ordered the banjo bolt, should I have bought the one that came with a snubber instead? Will the needle bounce?
What tubing is the best/safest to run since fuel will be going into the cab?
Postby CumminsPower59 » Mon May 09, 2016 5:06 am
Well, some get away with running the fuel line into the cab, but I have an isolator on my mess. Uses antifreeze/coolant on the other side. Has worked flawlessly for many years. It's easier to get the banjo with the "snubber" built in, or get a needle valve from a hardware store and add it after the banjo. If you run the line off the regular banjo directly to the gauge, you're wasting money as you'll kill the gauge with the pulsating pressure.
Postby spencerdiesel » Mon May 09, 2016 10:58 am
I'd love to plumb an isolator but every one I've looked at is astronomically pricy....so the guage would live if I installed a needle valve after the banjo?
Postby CumminsPower59 » Mon May 09, 2016 1:29 pm
You're looking in the wrong place then...I think mine was $50...
Postby RCCUMMINS89 » Wed May 11, 2016 11:53 pm
I literally run the boost gauge kit, and hook it up like an oil pressure gauge.
I have zero needle bounce by leaving air in the lines. Simple and affordable. Never had a failure.
