low pressure lift pump installed results
Postby bigtrev » Wed Sep 23, 2015 9:10 pm
Installed hungry diesels lift pump upgrade very good product it runs 12.5 psi at idle 14-15 at cruising speed and the thing that scares me when u let off from low rpm my 15 psi guage pins the needle at full hopefully doesn't blown any thing out so far so good it has been 2 weeks loving the power to the top and I swear the trucks running different because she will break loose in all gears in the rain now and I could barely break loose in 3rd before also put in hungry diesels fuel pin and did full pump reseal most I could pull her down to is just over 6 psi
bigtrev
Re: low pressure lift pump installed results
Postby RCCUMMINS89 » Thu Sep 24, 2015 9:39 am
What are your mods? Fuel filter health? Line size?
Your psi readings are rather low. Should idle at 15.
Postby bigtrev » Thu Sep 24, 2015 7:16 pm
Fuel filter is a wix water separator with fuel heater delete it's got probably 3000 kms on it stock fuel lines pump turned up and tuned at the most I can get out of her including the hot screw fuel pin and 3200 gov spring 4 inch turbo back exhaust 16 cm housing and 60 mm cold side on turbo cold air intake and just did full injection pump reseal stock injecrors far as I know truck has 404000 kms haha holds 35 psi
bigtrev
Postby RCCUMMINS89 » Fri Sep 25, 2015 7:50 pm
That set up normally runs 15 at idle, and about 10-12 at wot with those numbers. You're still completely fine and getting plenty of fuel, but if you ever wanted more, I'd recommend putting on larger lines to start.
Postby bigtrev » Thu Nov 26, 2015 12:06 am
So just thout I would do a little update on this. I did killer dowel pin this weekend my pin was still fully seated while I was in there I did the lip seal, red locktite on the injection pump as I was seeing allot of extra oil on the dip stick after the new lift pump. Checked all the bolts took them out lock tited and Re torqued they wer finger loose as most ppl have described in forums 407000 kms on the truck now when I fired it up the fuel pressure gauge was reading a 3 psi more than before also changed fuel filter at the same time if I could recommend somthing to us mildly modded guys I think 12 psi is wer a guy wants to be the pump would still supply great fuel and not have near the problems you get from the spikes after a good pull (ive seen 18psi) or just the sheer pressure of this pump
bigtrev
Postby RCCUMMINS89 » Thu Nov 26, 2015 1:47 pm
We used to offer a 12 psi pump for these reasons. But after about 3 years and not a single front seal failure that I was aware of, we discontinued the 12 psi pump.
As to date, I have been aware of 2 or 3 front seal failures of close to 800 pumps sold.
However, we may start offering the 12 psi pump again.
Just an fyi though.......the Cummins low pressure pump used in some of the ag applications, runs 18-20.
Postby bigtrev » Thu Nov 26, 2015 3:57 pm
That's for the reply I hoped u had a response is it possible to change the spring inside if so is there some where I could get one ...???
bigtrev
Postby RCCUMMINS89 » Thu Nov 26, 2015 4:02 pm
Anytime one wants the 12 psi spring........At the time of purchase, it is an extra $20 and about a week wait time.
Afterwards..... If one simply wants it, $20 and a week wait time. I'll walk you through on how to change it.
If it is a seal failure.....that is covered under warranty and it is a free swap for life. And I'll walk you through on how to change it.
Postby bigtrev » Thu Dec 03, 2015 9:31 pm
So now Iam stumped ive only been done the kdp, seal swap for a week and my pressure is back where it was at 12-13 psi is my filter plugging up this fast no sign of diesel in the oil, oil levels are staying the same so I don't think it's the seal again any ideas ???
bigtrev
Postby RCCUMMINS89 » Thu Dec 03, 2015 9:43 pm
Ambient fuel temperature will vary the psi readings quite a bit. It is common for a low cold psi, that comes up with temp. Fuel thickens, harder to pump.
That's the first thing that comes to mind.
Postby CumminsPower59 » Fri Dec 04, 2015 10:14 am
Have you pulled the inlet line off the lift pump and verified that the screen is clear? It's always a good idea to use a cheap in-line strainer before the lift pump to keep the big junk out ;)
Postby bigtrev » Sat Apr 16, 2016 8:16 am
New problem hahaha now i have something very weird going on my gauge is all of a sudden reading 6-15 6-15 and bouncing back and forth at idle any ideas guys
Also found. A junk yard he300vg turbo does any one know if this takes same parts as he351 for rebuild I have searched and searched and cannot find the answers
bigtrev
Postby RCCUMMINS89 » Sat Apr 16, 2016 8:34 am
Do you have a needle valve, or a snubber, or air in the lines?
Postby bigtrev » Sat Apr 16, 2016 12:17 pm
Fixed bled the line to the gauge and it stopped something I did notice , I have my truck set up with cable shut off when I turn the key off and leave engine running the gauge goes up 1.5 psi any ideas
bigtrev
Postby RCCUMMINS89 » Sat Apr 16, 2016 1:14 pm
Didn't gut your fss?
Users browsing this forum: No registered users and 77 guests
