Takes what to beat a 7.3
All of 'em
Postby spencerdiesel » Wed Nov 18, 2015 8:01 am
Hey there, my bud has an OBS stroker ('97) 4x4 zf5 with 6 pos. chip, 3in to 5in straight pipe, and minor intake mods.
I know the OBS 7.3s were non IC and have smaller injectors than the super dutys, I've heard roughly 280 rwhp is doable on stock injectors.
So what do these trucks weigh for a extended cab extended bed? I liked the way his truck ran on the hot tune.
Cuz our dodges are a little lighter, what rwhp would it take for me to be as quick as his?
Mine weighed in at 7k on the nose with full tank.
Re: Takes what to beat a 7.3
Postby simplysmn » Sat Dec 12, 2015 11:12 pm
All it Takes is a good Tow Truck they never make it back home without Breaking Down :D :D :D :D :D
simplysmn
Postby fatty » Sat Dec 12, 2015 11:14 pm
Takes almost nothing. Those OBS 7.3 are the slowest creatures on earth. I beat my buddy in his 96 auto while driving my 1988 Toyota pickup on the freeway. Thats how slow they are.
Postby spencerdiesel » Sun Dec 13, 2015 10:56 am
Hahaha ok. His truck got totaled, and now he's got a 97 built auto single cab. Same mods done to it and I timed it at 7.8 sec 0-60. Not gonna race the new slushbox equipped truck
Postby spencerdiesel » Sat Jan 09, 2016 9:13 am
So first off, I apologize because ya'll were right :) The video he sent me that I timed must have been down a 12% grade, because he let me drive it and it runs a 10 sec 0-60.......
His converter stays locked in direct and OD down to 1800ish rpm, and it's a 4.10 truck like mine. So that makes the comparison a bit more accurate to my 5 speed.
There's a 10% grade 1/4 mile long hill I always do my WOT tests on. Starting the hill at 45 in 4th and letting out before the hill starts to round off, my truck hit 61 mph.
Same day same variables, his truck locked in direct starting at 45 hit 63 mph. That's with 3" to 5" straight pipe, updated compressor wheel, and 6 pos chip on 140 (hottest) tune.
So if my 40 hp-over-stock truck almost stays with his "140 over stock" truck, that tune adds not even close to 140 horse.........stock HPOP not keeping up you think?
Postby Remps » Sat Jan 09, 2016 1:37 pm
Shetland VS Clydesdale, powerstroke vs cummins. :lol: max the fuel screw and blow his doors off. :lol:
Postby spencerdiesel » Sat Jan 09, 2016 7:46 pm
I would if I hadn't done something of massive ignoramusness to my clutch several months back :shock: :oops: :cry:
Postby spencerdiesel » Sat Jan 09, 2016 7:47 pm
Long story short it's got about a third of its life shaved (or roasted) off.....
Postby DMan1198 » Sun Jan 10, 2016 9:49 pm
I did that once when I dropped my counter shaft, and had to start out in 4th. Boy did it ever smell of clutch after that
Postby spencerdiesel » Mon Jan 11, 2016 7:34 am
Yep but mine suffered from my peer pressure based stupidity :roll:
Ill turn her up till she starts slipping, then back off a half turn or so. What hp do most of the factory clutches make it to before they slip?
Postby PToombs » Mon Jan 11, 2016 5:19 pm
162 hp. :lol:
Postby spencerdiesel » Mon Jan 11, 2016 8:02 pm
Bahahaha! Good solid experience Pete? :lol:
Postby PToombs » Tue Jan 12, 2016 5:22 pm
Nah, just joking. ;) Mine was pretty good for a long time. Like you've experienced, if you slip them they get glazed and don't hold as well.
Postby spencerdiesel » Wed Jan 13, 2016 7:05 am
Well dang I was hoping I had someone in the same boat as me :D
It doesn't slip any right now, but it's scary how much higher up the pedal is when it engages now :cry:
Postby DMan1198 » Thu Jan 14, 2016 10:58 pm
If they haven't been slipped they can hold close to 400. Once slipped a bit less. I know I was at that point with the silver bullet 62. I had to change my driving style to keep it from slipping any more (basically just easing into it after a shift did the trick)
Return to Other diesels
