Can't Start My Truck With Key!
Postby Bigred95 » Wed Jan 13, 2016 9:29 pm
So I bought this 93 4x4 5 speed with a push start button. If I turn the key forward everything comes on besides the information panel. If I hold the key in run position the wait to start and brake light comes on. My grid heater is not working either. I bought a new ignition switch, starter, and relays but still nothing. I need options and suggestions.... Fuses maybe? Help very much needed!
Bigred95
smoke screw?
Re: Can't Start My Truck With Key!
Postby thrashingcows » Wed Jan 13, 2016 11:10 pm
Do you have a Factory Service manual (FSM)? One of the best tools you can have for working on these old trucks. ;) Looks like you need to break out the test light and start checking wiring and circuits....which is much easier with the FSM as a guide.
You can get the printed version or CD from Geno's garage.
thrashingcows
Postby PToombs » Thu Jan 14, 2016 5:34 pm
Welcome! An FSM is a must have if you are going to work on the truck yourself. It may be as simple as a fusable link on the fender not supplying power to part of the fuse box, or a bad wire some place.
Return to Electrical
