Who likes what lube
Re: Who likes what lube
Postby spencerdiesel » Mon Jan 04, 2016 7:37 pm
Haha thanks guys. Just for curiosity sake, how loud do your tranny's talk back?
Postby spencerdiesel » Mon Jan 04, 2016 7:40 pm
And don't give the answer I know you'd love to ;)
Postby PToombs » Tue Jan 05, 2016 5:58 pm
Man, you just took all the fun right outta that one! :( :? :cry:
Postby spencerdiesel » Tue Jan 05, 2016 7:13 pm
Pete that meant "fire away" :roll:
Come on now ;)
Postby spencerdiesel » Thu Jan 14, 2016 7:16 am
For mpg purposes, what benefit would be realized by changing out every fluid in the driveline with good synthetics?
For me, there is a BIG difference in sluggishness (I think mostly in the gear lubes) from 70 deg to 30 or so. On the same hill with all other variables constant, my EGTs can and have been as much as 100 deg HIGHER on a colder day.
I know there's a TON of variables between winter and summer (fuel, temp, tire pressure etc), but my commute is consistently 70 miles per day (80% highway). There is a consistent 2 to 2.5 mpg loss in the winter.
Most people probably won't care to delve this deep Into something this minute, but I'm a little special Ive been told :roll:
Postby PToombs » Thu Jan 14, 2016 5:30 pm
spencerdiesel wrote: but I'm a little special Ive been told :roll:
I think most of us may have noticed that! :mrgreen: Probably most of that loss is the change to winter fuel, more so than extra drag from thicker oil. The winter fuel is cut with kerosene most of the time, and that burns a little hotter because it's a dryer fuel (less lube in it) which could explain the hotter temp.
Postby Remps » Thu Jan 14, 2016 7:48 pm
My egts are higher when starting out in cold weather as well, till the drivetrain warms up. Then egt is lower after a few miles. The slower you go, the more miles it will take to build up drivetrain heat. Google "cummins secrets to better fuel economy" pdf. Numbers an charts an stuff. Apparently driving through denser colder air creates more aerodynamic drag as well. Makes sense, never thought about it till I read it though.
Postby spencerdiesel » Thu Jan 14, 2016 8:39 pm
Pete, you're awesome :D
Remps, great idea never considered that 8)
Postby PToombs » Fri Jan 15, 2016 5:38 pm
spencerdiesel wrote:Pete, you're awesome :D
Thanks, but you need to tell the women in my area, that would be a bigger help than telling these guys! ;)
Postby spencerdiesel » Sat Jan 23, 2016 12:02 pm
What does it mean when the shifter moves with throttle input when in 5th?
Postby PToombs » Sat Jan 23, 2016 6:48 pm
Side to side or front to back? Side to side would most likely be engine mounts, front to back might be a loose main shaft.
Postby spencerdiesel » Sat Jan 23, 2016 8:42 pm
Front to back
Postby PToombs » Sun Jan 24, 2016 1:52 pm
Not good, you might want to look into that. Only in 5th? maybe a bad synchro. Bill or Andrew may have a better idea.
Postby spencerdiesel » Sun Jan 24, 2016 4:21 pm
Alright, yes only in 5th. I know getrags aren't as serviceable as 4500's, but are they nigh impossible to get parts for too?
Postby spencerdiesel » Sun Jan 24, 2016 4:22 pm
I noticed it about a month or so ago
