drag racing the getrag
Postby rollieD250 » Fri Feb 12, 2016 8:28 pm
only got to put 200 miles on my truck after i finished the body on it before winter, but in the spring i will add a 62SXE and 5x14's...and then hit the track.
i have hit the track 4 or 5 times in my 2nd gen nv4500 truck, launching in 3rd and it has held up....so far
what kind of luck are you guys having drag racing the getrag with 400ish hp? id like it to survive a little while anyway haha
1992 D250
THD fuel pin, 3200 spring, 57/65/14, timing spacer, 3pc manifold, piston lift pump, ASA intake
rollieD250
Re: drag racing the getrag
Postby DMan1198 » Fri Feb 12, 2016 8:55 pm
I'll be finding that out as well this summer now that my 1st gen runs again with my compounds, and I'll be sticking some honed 5x16's. I think I'll swap my secondary from the hybrid wh1c/hx40 to a 62sxe at some point. My dilemma is going with a .7 gated housing or a .63 single scroll non gated housing, and add an e-gate to the manifold. Even with totally killing the twin scroll effect on my secondary response is much better than the silver bullet 62 I pulled off
Postby spencerdiesel » Sun Feb 14, 2016 4:54 pm
What injectors are in it now Dman? Ever dyno?
Postby DMan1198 » Sun Feb 14, 2016 8:34 pm
I have ddp stage 3's in for right now. I'll be switching to a set of 5x16's I got from Eric as soon as I can get the bodies swapped. I also have a 188/220 cam I'm thinking about putting in.
It sat on a dyno for a few minutes a couple years ago, but was sucking air into the fuel system, and couldn't make a run. Since then I added a sump, dual filters, completely bypassing the stock feed side, and swapped from a 62/74/.8 single to a 60/67 compound setup that spools a lot faster. Now I just need studs, a clutch, and to do all the little things I want to get done.
Postby spencerdiesel » Sun Feb 14, 2016 8:40 pm
What size is a ddp 3?
Postby DMan1198 » Sun Feb 14, 2016 10:11 pm
About 55lpm or a little more than stock non ic sticks, but with better flow characteristics
Postby Tacoclaw » Mon Feb 15, 2016 4:33 am
I ran my 'rag a couple of times at the strip, I've got 3.07s and 35s so there wasn't any starting in 3rd for me. The 2nd to 3rd shift was a killer, huge ratio change and a tough shift to make in the first place. If you've got the gear/weight to take off in 3rd I'd say it would benefit you greatly.
Postby spencerdiesel » Mon Feb 15, 2016 7:46 am
Taco what does 3000 get you in each gear mph wise?
Postby Tacoclaw » Mon Feb 15, 2016 8:38 am
18mph in 1st
34mph in 2nd
64mph in 3rd
102mph in 4th
142mph in 5th
http://www.grimmjeeper.com/gears.html
Postby rollieD250 » Mon Feb 15, 2016 2:11 pm
Tacoclaw wrote:I ran my 'rag a couple of times at the strip, I've got 3.07s and 35s so there wasn't any starting in 3rd for me. The 2nd to 3rd shift was a killer, huge ratio change and a tough shift to make in the first place. If you've got the gear/weight to take off in 3rd I'd say it would benefit you greatly.
I have 4.10's and 30" tires :roll: :roll: so 3rd gear will be no big deal. Im going to try and swap to 3.55 before the summer
1992 D250
rollieD250
Postby spencerdiesel » Mon Feb 15, 2016 3:27 pm
Taco you haul balls :lol:
Rollie we're in the same boat, I couldn't even hit 40 in 3rd before I swapped gov springs, and 76 mph top out was pretty embarrassing......
Postby rollieD250 » Mon Feb 15, 2016 5:15 pm
Yeah i really think the swap to 3.55 will be money very, very well spent, still not sure if i want that new 62SXE or if i want to get one of erics new twin set ups and run s300g/475
Decisions....
1992 D250
rollieD250
Postby PToombs » Mon Feb 15, 2016 5:19 pm
4th gear, 3500rpms, about 95 mph with 3.55's. :mrgreen:
Postby spencerdiesel » Mon Feb 15, 2016 5:20 pm
Whats your opinion on the timing spacer, notice a difference?
Postby spencerdiesel » Mon Feb 15, 2016 5:21 pm
Got any exciting vids Pete?
Of trucks :D
Return to Competition
