front end alignment
front end alignment
Postby hoghead » Mon Jan 08, 2007 8:30 pm
do you have to go to a specialty shop to get a big dually aligned. I put on a tie rod end and I think it should have an alignment to save my tires.
1992 dodge d350 dually automatic 3:54 gear, borgeson steering shaft, cheap tps fix
hoghead
Postby darkvader » Tue Jan 09, 2007 4:46 pm
my 4x4 i use a tape and set about 1/8 toe
Clark
92 w250 5speed straight pipe
darkvader
smoke screw?
Postby dpuckett » Sat Jan 20, 2007 10:40 am
Normally if they can do a SRW 3/4ton, they can do a dually. Dont be surprised if they want to charge an extra $10 for putting 2 adaptors on (shops will do anything for a buck these days), though. Some dont, though. ALso be sure to ask what the shop set them to (number, not just "factory specs"), and compare it to the FSM recommendations.
Daniel
Postby MMiller » Sat Jan 20, 2007 12:24 pm
darkvader wrote:my 4x4 i use a tape and set about 1/8 toe
Clark
I agree, I put mine as close to straight as possible with a little tow in. There's no other adjustments on a 4X4, unless you start buying offset bushings for the "kingpins".
2wd however, I know nothing about.
Michael
MMiller
Postby JLeonard » Mon Jan 22, 2007 9:33 am
Not true Daniel.
My son just bought an alignmernt rack specifically so he could align duallys. He got away with doing some of them on his old machine, but he wasn't supposed to put a dually on it. The machine didn't have the nads to lift them all.
Best is to ask specifically if they can handle a dually. Around here, most cannot.
Jay
91 D250 w/modified Cummins, 89 D250 donor (future boat engine)
JLeonard
Postby Greenleaf » Tue Jan 23, 2007 9:53 am
I have to take my D250 to an OTR truck /frame shop for alignment. The local that service the Honda Civic cannot lift my rigs.
Greenleaf
tech specialist/mod
Postby dpuckett » Thu Jan 25, 2007 7:50 pm
Most of them around the Poplar Bluff area had no lift- just drive up a ramp to about 18" off the ground, and they hook up the stuff and see what needs to move where. I assumed if they could do a 6000# 3/4ton, they could to a 6000# dually.
DP
Postby CAJUN 93 » Fri Jan 26, 2007 6:47 am
some of the older machine's wheel adapters would not clear a dually's front wheel. if the shop cheaped out and bought a machine just to do cars and light duty trucks, thats what they got.
most modern machines have the capability to enter the VIN# and print out before and after readings. a compotent shop will be willing to give you the printouts. if they have the ability and still won't show you, be afraid, be very afraid :? .
i'm lucky in that i get mine done at work :) , i'm not so lucky in that my suspension tech is not so good :cry:
CAJUN 93
