Fixing to renew my steering
Postby BC847 » Sat Mar 05, 2016 4:57 pm
The heap is on safety stands, cleaned and drying. I've got:
- Redhead steering box (to replace the stock/OEM unit with 275k+ miles).
- New Borgeson pump with increased flow and pressure (to replace the eight or so year old unit with blown internal seal).
- New hydraulic lineset (to connect the above).
- New draglink (to replace a ten-plus year old unit that has damaged/missing grease seals).
- New tie-rod ends (to replace the stock/OEM units).
I'm planning on doing the work pretty-much by the FSM methods. Anybody want a "How-To" or specific pics about the process?
Re: Fixing to renew my steering
Postby ellis93 » Sat Mar 05, 2016 6:34 pm
Sure....I enjoy your write ups. It's nice to see how others do things.
Postby fatty » Sat Mar 05, 2016 9:00 pm
I want a write up. That way if mine ever needs done I can just read your writeup and it'll be easy for me.
Postby spencerdiesel » Sun Mar 06, 2016 10:20 am
Me three :lol:
Postby BC847 » Sun Mar 06, 2016 9:22 pm
Got the pump replaced and got as far as removing the steering box. . . . . . . to be continued.
