Excursion 12v/nv4500
Re: Excursion 12v/nv4500
Postby Gots_a_sol » Sat Apr 02, 2016 9:31 am
Started collecting parts to put my York compressor back on. I'll be sticking it on the drivers side since that is the only place I have room which means the stock oil fill is in the way.
Oil fill valve cover + timing cover plug.
On an unrelated note, I made a new sub box to hide my little 8" inside the front jump seat base (I use it flipped down as a console, never planned for anybody to sit there)
Then a bunch of dust and sparks later I got this mocked up
And meow. I just need to get some foam to fill in under the cover.
-Joe
Gots_a_sol
Postby Gots_a_sol » Tue Apr 05, 2016 6:31 am
Burned up the rear end this morning on my way to KY. I was only about 120 miles out and managed to limp all the way home in front wheel drive after pulling the drive shaft. She locked up in front of my house when I went to back my trailer in the driveway. Ugh, so much for that toy I was going to buy today.
-Joe
Gots_a_sol
Postby dazedandconfused » Tue Apr 05, 2016 8:35 am
That sucks. Sorry to hear.
Postby Gots_a_sol » Tue Apr 05, 2016 11:30 am
:mad:
Thanks rust.
-Joe
Gots_a_sol
Postby dazedandconfused » Tue Apr 05, 2016 11:48 am
What are we looking at?
Postby Gots_a_sol » Tue Apr 05, 2016 12:16 pm
That little white spot in the middle is a rust hole in the diff cover.
Since I'll be rebuilding the rear now, I'm going to throw the stock non-functioning limited slip carrier in the trash and put a Detroit Truetrac in its place. It is $315 for a lsd rebuild kit but only $560 for the detroit.
Ordered a new R&P, overhaul kit, and an oem finned aluminum diff cover. About to order the TT.
-Joe
Gots_a_sol
Postby Gots_a_sol » Tue Apr 05, 2016 12:39 pm
derp
-Joe
Gots_a_sol
Postby dazedandconfused » Tue Apr 05, 2016 1:00 pm
Do you have much rust on your truck?
Postby Gots_a_sol » Tue Apr 05, 2016 1:13 pm
There is one spot on the inner rocker on each side where the side steps bolt on, but it is pretty clean underneath other than that. And the diff cover :x
-Joe
Gots_a_sol
Postby dazedandconfused » Tue Apr 05, 2016 1:35 pm
I'm getting ready to put my engine in mine. How much room do you have with the manifold flipped between the turbo and heater box?
Postby Gots_a_sol » Tue Apr 05, 2016 2:25 pm
Not sure how well this shows it, but here is a pic
-Joe
Gots_a_sol
Postby dazedandconfused » Tue Apr 05, 2016 3:25 pm
Cool thanks.
Postby Gots_a_sol » Thu Apr 07, 2016 11:03 am
Just waiting on the new diff cover (oem finned aluminum one).
-Joe
Gots_a_sol
Postby Gots_a_sol » Fri Apr 08, 2016 11:02 am
Well, that is a little more carnage than I was expecting.
-Joe
Gots_a_sol
Postby dazedandconfused » Fri Apr 08, 2016 11:09 am
Holly sthi.
