Manual trans tilt steering column mash up
both inside and out
Postby JeffTheMarine » Tue Apr 05, 2016 3:38 pm
I've been thinking about this for a while and I haven't done any research about it. I am sure someone somewhere has done this so I figured I would ask about the info before I dive into it myself. I have taken apart several Chrysler steering columns from the late 60's-mid 70's and matched parts together to get what I need so I am sure that doing this with an 80's column can't be much different. I am looking to combine a manual transmission steering column with the automatic only option tilt steering wheel. I have been told that tilt wheels were sourced for Chrysler from GM parts/GM's supplier so the actual tilt mechanism is supposed to be the same with the Chrysler exterior of the column. I am have and will always have a manual trans but I would like to have a tilt wheel without going aftermarket. Has anyone on this forum tried something like this yet? If so advice... info....
Thanks
Jeff
1981 Dodge W250 Crew W/94 12V&NV4500+NP205
Mods: Ground #100Plate,AFC Foot ground,BHAF
1990 Dodge D250 NonIC 12V Smoke screw flush,Fuel pin turned, Star wheel bottomed -5 clicks, fuel screw in 1 extra turn
JeffTheMarine
Re: Manual trans tilt steering column mash up
Postby liftarc » Wed Apr 06, 2016 7:34 pm
My 92 W250 5 speed donor has a tilt column, are you sure its an auto only option? Theres gotta be more manuals with tilt out there
92 D350 club cab flatbed dually-201k G360, NP205,D60 swap soon
92 Ramcharger 5.9 Magnum, 46rh, NP241-238k
liftarc
Postby JeffTheMarine » Thu Apr 07, 2016 7:34 am
I have never seen one and have always been told they didn't offer them. I would love to see some pictures of yours. Or if you're interested in selling the one you have let me know.
Thanks
Jeff
JeffTheMarine
Postby captmatthew1 » Mon Apr 11, 2016 7:01 pm
my truck is a factory 5 speed with tilt. definitely not an auto only option!
1992 W250 5 speed, pump maxxed, 366 spring, caravan seats, white gauges, more to come.
captmatthew1
Postby Richie O » Mon Apr 11, 2016 8:32 pm
His 90 may have the older column like my 89 has. Not sure, but wasn't the older ones different? I also didn't think the 89 had a tilt as an option? Could be wrong. Have forgotten about everything I did know about these piles.
Postby matthewh » Tue Apr 12, 2016 1:09 pm
I looked into this before, trying to swap columns around between truck. My understanding is before '92, auto columns were built by X mfg, and manual columns were built by Y mfg. Because of this, you couldn't take parts from an auto column and fix a manual column, vice versa.
Now in '92, they went to a standardized column, didn't matter if it was an auto, manual, tilt or not, the components were basically the same and you could swap things around.
I've got a '93 5spd with tilt, and used parts from a gasser '93 5spd non tilt to repair a non tilt auto column in my 92 plow truck
You may be further ahead to source a column from a post 92 manual truck with tilt and figure out the wiring to your truck
matthewh
Return to Body
