swank wrote:I guess I'll switch out the marker lights for regular bulbs then, because I already have the "no load" flasher relay. I wonder why the trailer lights make it work then?
Philip wrote:I don't know why it works with the trailer lights. Those are a different circuit as far as the wiring is concerned. When I changed to LED front turn signals it didn't matter if a trailer was on or not. The crossed circuits in the front caused problems on both ends of the truck. I bet if you towed at night you would have had the same problem. The front turns grounds threw the market circuits. With power on the markers there would be no ground path.
