Kdp got me
Kdp got me
Postby 92cummins89 » Mon Apr 25, 2016 6:28 pm
Well the timing housing is cracked not bad just a little split
Got me a new timing housing
But considering just taken off the cover to asses the damage an hopefully everything looks good
If it does was considering just jb welding the crack any ideas or thoughts
1992 4x4, 4” diamond eye exhaust, nv4500, he351cw
92cummins89
Re: Kdp got me
Postby thrashingcows » Mon Apr 25, 2016 6:49 pm
Wow first KDP victim I've seen a bunch of years. Sorry for your luck man. :cry:
I wouldn't waste my time with trying to JB weld the case. Doubt if it would hold long term.
thrashingcows
Re: Kdp got me
Postby 92cummins89 » Mon Apr 25, 2016 6:56 pm
Well think it was cracked when I bought it
There a thread or a step by step on how to do or help
92cummins89
Re: Kdp got me
Postby CumminsPower59 » Tue Apr 26, 2016 5:11 am
FSM ;)
Re: Kdp got me
Postby 92cummins89 » Tue Apr 26, 2016 6:47 pm
92cummins89
Re: Kdp got me
Postby Richie O » Tue Apr 26, 2016 7:22 pm
Factory Service Manual.
Re: Kdp got me
Postby 92cummins89 » Wed Apr 27, 2016 8:49 pm
Ahh don't exactly have one lol
92cummins89
Re: Kdp got me
Postby CumminsPower59 » Fri Apr 29, 2016 8:10 am
Well.....whatcha waitin fer?!?!?!? Best money spent on any 1st gen is a FSM. Get it on CD and you can print off what you want/need.
Re: Kdp got me
Postby matthewh » Sat Apr 30, 2016 6:10 pm
I'm sure this has been beat to death before, but....
How common is the KDP? Until I really got into the forums, and reading build threads, id never heard of said issue. Dads truck went 298k before we parted it out and never had any issue, never tore it down fo tap the pin. Seems everybody I talk to around here it a case of " my brothers buddy had it happen to him" sorta thing. They fix it cause the magazine told them its the first thing to do. I understand the damage it can do, but in reality, what's the percentage of motors that have issues? We talking 50%, or more?
Granted, I'm gonna do mine when I get around to it, as a precautionary item, just wondered how accurate the issue is.
Just searching for knowledge, nit trying to pick a fight or anything like that
matthewh
Re: Kdp got me
Postby PToombs » Sun May 01, 2016 12:46 pm
I know on our trucks the percentage is low, the 2nd gens were hardest hit. The 1st gens had a bigger problem with the case bolts coming out. I have seen 2 or 3 of these myself, but my own truck they were tight and the pin was bottomed out.
Re: Kdp got me
Postby spencerdiesel » Sun May 08, 2016 2:20 pm
My kdp looked like it hadn't moved at all, but the truck only had 160k at the time. Pete's right about those bolts, one of mine was "umph" finger tight.....
Re: Kdp got me
Postby 1320Fastback » Thu Jul 28, 2016 9:00 pm
My KDP hadn't moved but the case bolts were finger tight or less.
We had one engine at work years ago succumb to KDP destruction but only one I've seen.
92 D250, Getrag 5 Speed, 3.54, extra cab, long bed, AC works, Airbags.
1320Fastback
Re: Kdp got me
Postby DodgeFreak » Thu Jul 28, 2016 10:14 pm
how many have died from the case bolts??? has any ever fell completely out and wiped the gears? Ok I know there probably has been but I haven't heard of any. Most were caught because they was worried about the kdp.
Re: Kdp got me
Postby PToombs » Fri Jul 29, 2016 5:35 pm
There have been a few posted on here over the years, and yes, gears have gotten eaten, cams broken, cases cracked.
Re: Kdp got me
Postby jethro » Mon Aug 01, 2016 2:44 pm
Doesn't that mail order place near Atlanta that stocks a lot of our 1-st gen parts carry the front housing ????? (cant remember their name---- probably old-timers)
I put torque seal on all the front cover bolts so I might be able to see if any ever moved out later.....
tim
jethro
