pulled the Dana
put a 8 3/4 with a 3.55 in Temporary
went to the track again
still only made 3/4 track before running out of steam
last Friday night
first 2 passes, I don't know what I was thinking
only let engine get to 160* > used to the Dart on E-85
next 3 passes got temp to 180*
Tuesday night
using a blue holly pump, turned up to 10psi
removed the power screw collar, turn screw in
installed 3800 gov spring
bumped the pump another 1/8 toward the head, plus has skipped a tooth
results > looks like to much timing
slower 60ft and ET
MPH was better due to 3800 spring
interesting 2 passes
Friday night on the left
Tuesday night on the right
Next is back the timing back to where it was.
set up gears for the Dana and re-install
Sit next to the mail box> waiting on a HE351CW turbo to fall off the UPS truck
also looking for some 5 x 12 injectors
and saving my pennies for a modified injection pump> more flow
