1STGENFARMBOY wrote:I'm not blowing any horns untill i drive down the road and see if it works, but where I have worked for 28 years now I get all the stuff no body eles wants to try, so just maybe I can do it.....I hope
got a call from Georend a while ago and the converter is on it's way, I was hopping to have the trans done and all the other stuff and just wating on it.....but that is not going to happen.
sooooo...Cow, did you get a DVD or book to help you out, or did you just jump off and free fall through the hole thing.
DodgeFreak wrote:I think if it were me I'd pull the OD apart and soak the clutches. I would rather know they are completely soaked than to have the possibility of a failure on one of the weakest part of the transmissions. I'm just not sure well it would seep into the clutches, should be fine but there is always that chance. Especially the direct drive clutches as they are under pressure.
1STGENFARMBOY wrote:one funny thing, after I got the apply pistons together I thought it looked wrong so I went in and watched some vids......holy crap I must have went mental for a second....there was not 1 piece of them that wasn't upside down or backwards, looked good after they were done right.
Users browsing this forum: No registered users and 67 guests
