by 1STGENFARMBOY » Thu Oct 20, 2016 6:53 pm
OK ....problem, trans is together and full of fluid, ran the truck for 30 min in park and neutral, it won't move in any gear, but when I pull off a trans cooler line it pumps loads of fluid out, so to me that rules out the converter not being seated in the pump, and as I was bolting up the converter to the flex plate I could rotate the converter easily with my finger tips after I had the bell housing pulled up tight.
#1 remember I put a transgo kit in the valve body.....My gut is the valve body is not right and not putting the pressure where it needs to go.
#2 can someone that has a FSM tell me where to check pressures and what port to check, I think I can narrow it down if I know this.
If you guys think I am on the right track with the valve body, would anyone have one laying around I could stick in to see if that is it, if so I can buy one.
H E L P .....
Dar
