Controlling overdrive in an A-518 without an ECU
Postby Bookshelf » Sun Oct 23, 2016 10:11 pm
What would be the best way to control overdrive in a 518 without an ECU, and not using a toggle switch either? Thinking of using one in a repower. With the potentiometer in place of a TPS, I would still need an ECU, right? Thanks
91.0 W250 Auto
90 Chevy V30
Bookshelf
Re: Controlling overdrive in an A-518 without an ECU
Postby Philip » Mon Oct 24, 2016 6:47 am
TPS means nothing without a PCM in the system. The TPS sends a variable voltage signal that only the PCM can use. The OD solenoid is wanting an on/off ground signal.
Hook a pressure gage into the governor test port. Find the pressure that it supplies for the speed you want OD to come in at. Then pickup a 1/8 NPT pressure switch for that PSI at a parts store. It will turn on/off the OD at the same speed every time.
Now going this way remember if your towing heavy you have no way to delay OD engagement. I would still put some type of over ride switch on OD. Maybe a switch on the throttle linkage that drops the power to the OD above 3/4 throttle
Postby stuffy » Mon Oct 24, 2016 7:17 am
You can also get adjustable pressure switches. I think they're called Hobbs switches
92 w250
Silver Bullet, pump maxed, full manual 47re, 5x18s, Hungry Diesel piston pump
stuffy
Return to Transmission
